Garmin Golf Logix GPS Logo
Posted on Jun 08, 2009
Unit comes on and locks on a single hole and thaty's it.
It will not page off the single hole and I have to remove batteries to turn the unit off.
Anonymous
Level 1:
New Friend:
  • Contributor 63 Answers
  • Posted on Aug 10, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
63
Questions
0
Helped
11413
Points
80
You need to download the 3.5 software from golfgps.com and then update courses on your unit.
3answers
I have a dvdr3355.It has a rewritable dvd in it thatI have been using and has recorded programmes on it.I am trying to remove it but the window just says blocked and I cannot find a way to release it.Could...
If you cannot get the disk to eject, power the device off and insert a paper-clip into the emergency-eject hole in the front of the device. It should be located just under the disk tray.
1helpful
2answers
How do i change battery on trumeter 5505e
The device is not meant to have the battery changed (?!).
However, I am going to drill out the holes where the screws would go and try and change them myself. It doesn't not make 'consumer' sense to me to have this unit without being able to change the battery. It has a 5 year battery life but I only need this unit once in a while so in 5 years I may only use it once or twice.
Jun 07, 2013 • Cameras
1helpful
I have a 1998 Ford Contour. When I insert the key it will not turn. I have tried the standard stuff like wiggle the steering wheel, push in the brake and try to move the car from park, nothing! If I use...
You will most likely need to replace the ignition lock cylinder.
Functional Lock Cylinder
  1. Disconnect the negative battery cable.
  2. Remove the upper and lower steering column covers.
  3. Turn the ignition lock to the accessory position.
  4. Insert a 0.125 (3.17mm) wire pin or small drift punch in the hole at the top of the cylinder housing and depress the retaining pin while pulling out the lock cylinder To Install:
  5. Turn the new lock cylinder to accessory position and while pressing the retaining pin in, insert the lock cylinder into the housing.
  6. Turn the key to the OFF position the release the retaining pin.
  7. Try the lock cylinder operation in all positions.
  8. Reinstall the steering column covers.
  9. Reconnect the negative battery cable.
Non-Functional Lock Cylinder
  3. Insert a 0.125 (3.17mm) drill bit in the hole at the top of the cylinder housing and drill out the retaining pin. NOTE: Be careful not to drill into the lock cylinder housing.
  4. Pull out the lock cylinder.
  5. Clean out all the metal shavings and check the tube for damage. If damaged, the housing must be replaced. To Install:
  6. Turn the new lock cylinder to accessory position and while pressing the retaining pin in, insert the lock cylinder into the housing.
  7. Turn the key to the OFF position the release the retaining pin.
  8. Try the lock cylinder operation in all positions.
  9. Reinstall the steering column covers.
  10. Reconnect the negative battery cable.
Remove the three screws and remove the lower column cover
Releasing the lock cylinder retaining pin
Just put new batterys in safe . but safe will not stop bleeping what is the problem
Please follow these steps
Programming a user code
There are two ways to program a user code.
A 1. Press the Program key.
2. Enter the Factory Code. The green LED remains ON
while you enter the 5-digit user code of your choice.
After 5 digits are entered the green LED turns OFF.
(To enter a new User Code, repeat these steps.)
B 1. Press the red button inside the safe. The lock will
beep and the green LED will come on.
2. Enter a 5-digit user code.
Keep your new user code secure.
For your records, please copy it here:
____ ____ ____ ____ ____
Programming a password
2. Press it a second time.
3. Enter your 5-digit User Code. The green LED remains ON.
4. Enter the 5-digit Password of your choice (any combination
except 00000.) After 5 digits are entered, the green LED
turns OFF.
(To enter a new Password, repeat these steps. To erase the
Password, press Program twice, enter your User Code and then
enter 00000.)
Battery replacement
Below When old batteries are removed for replacement, your Password will be voided; only Factory and User Codes will work. To
reestablish your Password, follow the directions above under
Programming a Password.
Key override
If your electronic lock fails or you do not have any codes
available, you may use a key override to access this unit.
1. Remove the battery cover, disconnect and remove the
battery holder.
2. Insert the skeleton key (second set of keys provided)
into the key hole inside the opening for the battery.
3. Turn the key to the right.
4. Turn the four bit key to the right.
5. Open the door.
Signals
Your electronic-lock safe communicates by means of several
audio/visual signals.
Red (Error) LED + three beeps indicates
one of the following:
1. You have pressed Program key out of sequence
2. You have entered an invalid code or password.
3. You have let 5 seconds or more elapse between key entries.
Green (Proceed) LED + single beep occurs
1. After entering each digit of Factory or User Code, or
Password
2. After pressing Clear key
3. After pressing Program key
Green LED only
1. Comes on after you enter a valid code/password and
remains lit during the 4-second period in which the safe
can be opened.
2. Comes ON in the Program User Code mode after you enter
the Factory Code and remains lit until you have finished
entering a 5-digit User Code.
3. Comes ON in the Program Password mode after you have
entered your User Code and remains ON until you have
entered a 5-digit password.
Yellow LED
Indicates low battery and will typically not turn ON until
battery has been in use approximately two years or longer.
Your electronic lock automatically performs a low battery test
during each lock use.
If a �low battery� condition is detected the Yellow LED will
come ON and remain ON during each subsequent lock
operation. (The lock will continue to function in a Low Battery
state, until battery failure.) The Yellow LED will turn OFF only
after three consecutive Good Battery readings or after the low
batteries are replaced. (Note: If the new batteries are installed
in less than 60 seconds the Yellow LED may come ON and stay
ON during the first lock operation before it returns to OFF.)
NOTE: It is recommended you replace the batteries after two
years, or when the yellow LED remains on.
Making humming noise power not on door locked
turn off the unit.use a wet dry shop vac and attach it to the end of the drain hose this will remove all the water then you can turn it back on and should be able to open the door to get your clothes out.
after all thatis done you need to check the drain pump and make sure there is nothing blocking the pump.other likely problems are the door lock mechanism is bad or the main control board
I hear one single beep coming from computer and number lock and caps lock are blinking .. is this an issue with the mother board?
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer
UNIT COMES ON BUT LOCKS UP IMMEDIATELY
OK, the only things you can do is take it back or buy a new one, but here is a list of things that make PSPs do that:
1: Dropping them(Accident or not)
2: Putting water in them(So don't wash it)
3: Thumping them(Even if you lost that level)
4: Over-charging them(Charge it for 1-2 hours only)
5: Putting it in the microwave
6: Putting it in the oven
7: Leaving it in a steamy room
8: Removing the game while power is on
9: Bashing it with a hammer and finally...
...10: Opening it up and fiddling with the bits inside it.
No water to single hole faucet after installation
the cartridge has trash in it.remove and clean,will work after that is done.
CPU is locked!
remove the battery from the unit and allow it sit for a couple of minutes then plug in the unit to power and see if it somes up. Removing battery and power often unlocks a unit. make sure hibernation is not causing problem. Once it comes up successfully, power off and reinstall the battery, try again. Some times a failed/failing battery can lock things
Top Garmin GPS Experts
vince
Jesse Walters
Jesse Walters
Are you a Garmin GPS Expert? Answer questions, earn points and help others
