It depends on the tablet that you have. Usually non branded tablets tends to have lots of problem. It also could be that the radio could be corrupted. Radio is what it take care or manage the wifi, data, etc... anything with connectivity.
I do suggest that your try to flash the radio again if possible. If not, try these next steps:
1. Go tot he wifi connection and tap on forget, this is to make sure that you don't have any wifi saved.
2. Reboot your tablet.
3. Now search for the wifi again, set it up with all the requirement, like password, channels, etc.
4. Wait until it display saved even if it doesn't connect.
5. Reboot your tablet.
6. Try to connect again to the saved wifi. If it still doesn't connect, your only option is to flash the radio band.
It will say Authenticating problem unless you have the passkey to the other WiFi networks. So unless its your WiFi or an open network you won't be able to connect.But you can try rebooting your device.
Check your wifi password correctly. If you are the owner of the wifi router you are connecting try to press the refresh icon button located on the side of your router.
The issue isn't with the tablet, it is something in your Wifi...there are a number of things that it could be, try simply rebooting your router, that would be the easiest thing to try. If that doesn't work, try switching your tablet to "airplane mode" , and then try to connect...
wrong settings entered on tablet, try again.If possible connect tablet first via usb cable to computer or router to try connecting it , to determine the actual fault on connections.
