When trying to restore I receive receiving error 0x4001001300001002. the laptop reboots and goes into the recovery/startup repair screen. When you select the Dell Datasafe restore option, select restore to factory image. The formatting your partition check happens very quickly then the error pops up and the green circl keeps spinning by "reinstall your original content and the progress stops at 1%. Any help is appreciated. was try to reimage as the computer was real slow on boot up and regular operation. t was in the closet for 4 months not being used and my 13 month old windows 8 laptop just died.
SOURCE: My dell won't reboot. Goes
"Step 1 I would suggest you to boot the computer in safe mode and check if you can boot to the desktop and post back the result. To boot to the desktop in safe mode with networking keep tapping F8 key during restart. Once you see the option to boot in safe mode with networking select it and press enter. Access the link to know more about how to boot the computer in safe mode: http://windows.microsoft.com/en-US/windows-vista/Start-your-computer-in-safe-mode Step 2 If you are unable to boot to the computer in safe mode, you may try to perform a system restore from Windows Recovery Enviornment (WINRE Mode) to an earlier date and check if it helps you fix the issue. If you have Windows Vista disk you may try to perform a system restore using Windows Vista disk: a. Insert the installation disc. b. Restart your computer. c. If prompted, press any key to start Windows from the installation disc. Note: If your computer is not configured to start from a CD or DVD, check the information that came with your computer. You may need to change your computer's BIOS settings. For more information, see BIOS: frequently asked questions. d. Choose your language settings, and then click Next. e. Click Repair your computer. f. Select the operating system you want to repair, and then click Next. g. On the System Recovery Options menu, click System restore and select the date when the computer was working fine. If System Recovery Options is a preinstalled recovery option on your computer: a. Remove all floppy disks, CDs, and DVDs from your computer, and then restart your computer. Click the Start button, click the arrow next to the Lock button, and then click Restart. b. Do one of the following: • If your computer has a single operating system installed, press and hold the F8 key as your computer restarts. You need to press F8 before the Windows logo appears. If the Windows logo appears, you will need to try again by waiting until the Windows logon prompt appears, and then shutting down and restarting your computer. • If your computer has more than one operating system, use the arrow keys to highlight the operating system you want to repair, and then press and hold F8. c. On the Advanced Boot Options screen, use the arrow keys to highlight Repair your computer, and then press ENTER. (If Repair your computer is not listed as an option, then your computer does not include System Recovery Option as a preinstalled recovery option.) d. Select a keyboard layout, and then click next. e. Select a user name and enter the password, and then click OK. f. On the System Recovery Options menu, click system restore and restore the computer to the date it was working fine. After running the system restore check if you can boot to the desktop normally. Access the link below to find more information about system restore.
http://windows.microsoft.com/en-US/windows-vista/What-are-the-system-recovery-options-in-Windows-Vista
http://windows.microsoft.com/en-US/windows-vista/What-to-do-if-Windows-wont-start-correctly "
This guide should help you out
SOURCE: Error 0x400110020000100a
Unfortuneately you will need to go online, contact customer support and the technical department to order a new recovery disc for your make and model of laptop.
