Danco Faucet Stem  Logo
D
Deb S Posted on Sep 03, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Replaced faucet cartridge but can't seat stem properly
I purchased a 3s-16h/c cartride, set the spring and ubber gasket firmly inside, worked the cartridge in, tightened the nut and replaced the stem but it doesn't seat firmly. There's a small white piece included and I've tried it on both sides of the fixed one as well as leaving it off and I still can't get it to sit firmly enough that it doesn't wobble. What am I doing wrong?
Austin
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 83 Answers
  • Posted on Sep 04, 2017
Austin
Expert
Level 2:
New Friend:
Cheetah:
Answers
83
Questions
Helped
23552
Points
195
It sounds like you might be missing a part. Check your list for all included parts. All parts are critical.
3 Related Answers
Anonymous
  • 349 Answers
  • Posted on May 05, 2010
SOURCE: The handle on my outdoor faucet is broken. I
Have you checked with a plumbing supply hose if it is a square slot you may could use a handle off a boiler drain for a washing machine .
Check it out if it is a metal red or blue metal it may be the same type used on your washing machine cut off valve
Anonymous
  • 70 Answers
  • Posted on Aug 15, 2010
SOURCE: Where does the spring and rubber piece go when
http://kitchen-bath.hometownhardware.com/Faucet_parts-ssd70982-p9-l1-t1-Sv-dirasc-PP10.html
Anonymous
  • Posted on May 13, 2013
SOURCE: I bought a replacement Danko faucet cartridge for
remove the c clip (may be plastic or metal) on the top of the replacement part, the stop ring flips over to make it a hot or cold faucet
tip
Ball-Type Single Lever Faucets
BALL-TYPE SINGLE-LEVER FAUCETS
  • The single-handle faucet with a ball inside to control both hot and cold water may either leak at the spigot or at the handle. A handle leak is usually caused by improper adjusting-ring tension. Simply adjust the tension to stop the leak. Leaks at the handle can also result from a worn cam gasket. Dripping from the spigot is usually caused by worn spring-loaded, soft rubber seat assemblies.
  • Parts for ball-type faucets are available in kits. Get the spring/seats kit for spigot leaks, or the complete kit for handle leaks. It may be advisable to use the complete kit to replace all working parts of the faucet at the same time. In any case, you'll need a kit containing the spanner/hex wrench for removing the handle (hex end) and turning the adjusting ring (spanner end).
  • Without turning the water off, loosen the handle set screw. Slide the handle from its stem.
  • For a handle leak, try using the spanner wrench to tighten the adjusting collar. Tighten it by turning the wrench and collar clockwise until the faucet doesn't leak when it is turned on and off. If the adjustment is too loose, the faucet will leak. If you turn it too tight, the handle will be hard to move. When the adjusting ring cannot be turned with the wrench, it is corroded. At this point, you will need to remove the cap to free the adjusting ring. (See next step.) You must turn the water off before removing the cap! Apply penetrating oil to the threads, remove the ring and clean all parts before reassembling.
  • Install the seats. For faucet leaks at the spigot, you must install new rubber seats and springs. You must turn off the water to make this repair. Unscrew the chrome cap by turning it counterclockwise. If it won't turn easily, wrap electrical tape around the cap and turn it with pliers. The adjusting ring, which is threaded into the cap's center, will come off with it. For a seats/springs replacement, pull the ball up and out by its stem. The gasketed cam will come with it. Now you can locate the two rubber seats and springs inside the faucet body. Remove them with pliers or yours fingers and install the new ones. The springs go into the holes first, and the cupped sides of the seats fit over the springs.
  • Service the ball. If the ball is dirty or coated with scale, clean it or replace it with a new one. Both plastic and brass balls are available, but use a plastic one if your home has hard water.
  • Reassembly. Put the ball and cam back into the faucet with the slot in the side if the ball fitting over the pin in the faucet body. Then make sure the tab on the cam slips down into the notch in the body. Not aligning the tab and notch is the number one cause for a faucet leaking after it is repaired. Finally, screw on the cap and adjust the ring as described in Step 2. If a properly adjusted ball-type faucet leaks at the cap, the cam and gasket must be replaced.
  • Swing spouts. If a single-lever ball faucet leaks at the base, you should replace the O-rings. Remove the spout-retaining parts, as well as the spout. Wrap the spout-retaining nut with electrical tape to protect it, and remove the nut with a wrench or pliers by turning counterclockwise. Remove the spout by pulling it up and side-to-side. One or more O-rings should now be exposed. Take the O-rings to your hardware or home center store to get matching O-rings for replacement. Clean any scale that appears on the spout base, faucet body, and the inside of the swinging spout. Install the new O-rings and reverse the steps above to reassemble the faucet.
on Jan 16, 2010 • Plumbing
How do i put the o rings and springs in my old leaking 2 handle faucet
Make sure the water to the tap set is turned off. Remove the hot plug button, use a small knife to pry it out of the top of handle. Remove the screw inside the handle that holds the handle to the cartridge. Use an adjustable wrench to unscrew the tap handle from the base. Once removed, separate the cartridge from the shell (the unscrew from each other). Use the appropriate size and type of screw driver to remove the screw holding in the flat washer. Using a small dull needle or flat screwdriver remove the "O" ring from the valve stem Replace the o ring by just slipping it on. Make sure you clean all areas of the stem and the stem cartridge of old grease and dirt etc. Use new clean valve stem grease on the O ring before re installing into the cartridge. Insert the new washer onto bottom of valve stem, Screw on. While you have it apart look down inside the tap to inspect the valve seat. If its chipped, broken, rusted etc you MUST replace it, if you do not any new parts will sot stop the leak. Valve seat MUST be nice and flat and clean. To remove the seats most taps will require a 3/8" Allan wrench. Push the wrench into the slot of the seat, turn C-Cw to remove, CW to replace. These parts are cheap. If you need to replace the seat, take it with you to H Depot so they can give you the correct one. NOTE: Its best to do the cold at the same time, saves you the trouble of doing it again later. Same applies to the cartridges. You can replace the entire cartridge instead of rebuilding them at only a few bucks each, its much faster and easier.
My kitchen faucet handle makes a screaming sound and will not turn the cold off
Either you didn't seat the o rings properly or they are the wrong size or the cartridge needs replacing
Leaky faucet
If your faucet is dripping out of the spout. This is how to repair it if you have a faucet with this type of cartridge system
For details see diagram attached.
In the order you see. Valve nut, o-ring (may or may not be used in your valve) Valve Cartridge, Cup Washer and Spring.
Turn off the water to the valve at the water supply under the sink if you have shut-off valves there. Otherwise you will have to turn off the water to the whole house. Open some of the other faucets in the house if you have to turn the whole house water supply off at the water meter valve to reduce the line pressure. Open the handles of the faucet you are working on as well after you turn of the water either way.
If it has two handles there should be a set screw that holds the handle on. You will need the appropriate allen wrench for the set screw. Loosen that and wiggle the handle off the valve stem carefully. There is a brass nut that holds the valve cartridge in the valve body. Using a small pair of channel lock pliers or the appropriate box wrench. Loosen and remove that brass nut. Once that is off, grasp the valve stem with the channel locks and gently wiggle the valve as you pull upward. There will be some suction that wants to hold it in so this may take some finessing to loosen and remove. Be firm but gentile. Make sure you pay attention to the position the cartridge is in so you can place the cartridge back in the same position it was when you removed it. Otherwise, the handle will not be in the proper position when you put it back on.
Once you have the cartridge out. There should be a small black cup washer that sits in a hole on top of a spring at the bottom of the inside of the valve body. You should replace both the spring and cup washer.
You can find them at your local hardware store or big box DIY store.
I use a real small screwdriver to lift the washer and spring out.
When you go to place the new cup washer and spring back in place.
Place the spring in the whole with the larger side down. Then, to place the cup washer back. Place the cup washer on the small screwdriver and hold it with your index finger and lower it to the whole over the spring. Once you have the cup washer over the spring. You have to get the wider bottom part of the washer into the hole. Holding the washer down with your index finger. Use the small screwdriver tip to push the side of the washer into the hole working your way around the washer. Pressing the sides of the washer inward so the bottom edge pops into the hole over the spring. Once you fell the washer pop in and seat. Push straight down to get it fully placed. Then reverse the procedure you used above to remove the cartridge. Paying careful attention to the position the cartridge was in when you removed it and replacing it in the exact same position. There are o-rings or an o-ring around the cartridge so you'll have to wiggle the cartridge and press down to get it to seat level. Place the nut back over the cartridge and tighten down firmly. Replace the handle and tighten the set screw.
Jan 04, 2014 • Plumbing
1helpful
Looking for the stem unit diagram from delta for their single handle shower unit that uses the stem rp1991. in the info leaflet that comes with the replacement they refer to a spring. I want a diagram to...
You can go to the link below to get a parts breakdown of your style of Delta. The seats and springs are recessed into the valve body behind the RP1991 stem. The flat part of the stem rotates back and forth across surface of the rubber seat, so in time the rubber surface wears flat and the spring can no longer push it firmly against the stem.and then the faucet drips.
http://www.plumbingpartsdepot.com/delta1600.pdf
Aug 04, 2010 • Home
2helpful
How to insert a hot cold ste, 3Z-6H/C FAUCET REPAIR
#1 THE FAT PART OF YOUR SPRING GOES INSIDE THE FAUCET ,AND SIT ON THE VALVE BODY(SEAT)
#2 THE LITTLE BLACK WASHER SIT ON TOP OF YOUR SPRING
#3 PUSH THE STEMS IN THE CORRECT SIDES HOT ON LEFT.CAUTION THERE IS USUALLY NOTCHES ON THE SIDES OF THE STEMS TO HELP YOU ALIGN THEM IN THE VALVE BODY,
4 PUT THE NUT BACK ON ,TIGHEN SLIGHTLY,TURN ON THE WATER TO CHECK ,IF OK RE INSTALL YOUE HANDLES
2helpful
I have replaced the stem valve in my innovations two handle faucet but now the water will not shut off completely.
Remove it and make sure that the cup washer and spring are seated propoperly. The large end of the cone shaped spring sits on the bottom of the housing seat and cone washer slips over the small end of the spring. Use the shank of small screwdriver to guide the washer and spring by placing them on the shake in the proper order and then putting the shank into the housaing and sliding the washer and spring.
You may also have to disconnect the supply tube that connects to the faucet under your sink. This is to relieve the pressure within the valve housing which can cause the washer to become mis-aligned when installing the cartridge
. Also check cartridge for defects and make sure you have it install in the correct position i.e you may have to remove it rotate it 180 degrees re-install it and move the limit stop (if it has one, depends on year) inserted in the top to the correct side for propoer operation direction of the handle after you reverse it.
Hope this helps, sincerly T. Wood, C&F Enterprises, A Plumbing Contractor
Top Danco Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Danco Home Expert? Answer questions, earn points and help others
