My machine started to beep a few times and now only the feed button will work. I turned it off with the key several times with no luck. None of the button work. How do I fix this ?
I cannot get any keys to work. I have no sounds when I enter amounts. Lights still reflect. 0.00
Two very real possibilities. The machine received water damage, or the CPU blew up. Usually when you see all 0's in a display that is what it indicates. Sorry. Fortunately those are very cheap machines.
It's a shame, but you are discovering why many of us are returning to the old mechanical machines circa 1965 or earlier. The fact is these newer computerized machines have issues far more often than one would think.
If I were you I would call the support line for your machine. Ask directly if your machine has been recalled. And whether or not your motor (never heard of a feed dog motor) or board(s) are covered under the warranty. Ask them to confirm that via email.
To clear this
1. close washing machine door
2. turn dial to usual wash setting
3. press start button and keep pressing for several seconds - the problem should be solved.
sounds like a key is stuck on a keyboard. Rub your fingers all over the keyboard to make sure none of the keys are sticking. Then go ahead and turn on the laptop and see if the beeps stop. If that doesn't work, then disconnect the keyboard completely and turn on the laptop and see if the beeps stop and the laptop turns on.
If those two things don't work, unseat the memory and reseat it back into the slots one at a time and turn on the laptop after each reseat.
The beeps should go away and if they don't then you know the motherboard is starting to go bad.
It sounds like you just need some calibration. To calibrate incline, turn power on press press any incline buttons, as the incline try to change unplug the key. Now re-nsert key and incline will self calibrate,
Hi. Check for a paper jam inside the paper feeder... There's something blocking the path that is why the 3-beep is activated. Also put lubricant to the head's round-bar, gears and levers.
