I have a Nortel M7208 the display screen is working, but when I press any of the lines to make an outside call I get a ringtone. However; when I dial a phone number the keypad does not register the number pressed to make the call.
SOURCE: Call forwarding to outside line
To send a call to another telephone within your system, or to an external
telephone. You may not be able to transfer a call on an external line
to an external telephone, depending on the capabilities of the lines.
1. Make or answer a call.
2. Press the feature button then press 70.
3. Call the person you want to transfer the call to.
4. Stay on the line if you wish to speak to the person first.
5. Press the Release button to complete the transfer.
If an external call is transferred to a busy internal or network
extension, or is not answered after a few rings, the call automatically
rings you back.
SOURCE: SCREEN NOT DISPLAYING NUMBERS
If you haven't already tried it, unplug the phone, press a couple of buttons, then plug it back in so it resets. If the boxes still appear, try adjusting the display contrast. Press Feature-*-7 to get to contrast setting and then press 6 or 7 to set mid-range contrast.
SOURCE: Want to pick up phone and get an outside line
Yes, put your lines in a line pool, then have your phone automaticly go to Line Pool: <Whatever Pool # you picked, 1 thru 3>
SOURCE: Nortel T7316E Call Forwarding - Outside Line
The Nortel call forwarding (feature 4) is for forwarding the ringing and intercom from one extension to another.ex. if you were going to be working in the conference rm. instead of at your desk,with the forward on to the conference rm. extension, the calls you get at your desk will transfer to the conference rm. phone. Call forwarding through your service provider is done by accessing the telephone line you wish to forward, dial *72 (you should get dialtone reordered)and dial the telephone number to where you want the calls to be forwarded to. the party on where your forwarding the line to has to answer the line for the forward to take place. to remove call forwarding , access the line you have the forward on and dial * 73, you should recieve a stuttered dialtone for confirmation that the service is off
SOURCE: nortel phone m3904 won't forward to an outside line
The DN may not be configured to allow forwarding to an outside line for security reasons. I think the default is 4 digits. You will need to talk to whomever programs your switch and ask them to allow this feature.
