Hi, my Kettler Marathon TX1 stops abrubtly (error 40). Usually after 3-4 km of running at 6-8 km/h. I tried calibrating and clearing last error but the problem remains. What to do?
The motor or the Motor control board is faulty. Can be the motor brush or the shorted igbt transistor in the motor contol board. If you wish to get some more details about treadmill repair then check the following link. http://electro-medical.blogspot.com/
Please recalibrate the machine with software calibration, for easy diagnose, troubleshooting and fix it If the problem persist, you must need some basic parts or need service for repair. See hte block diagram attached. God bless you
adjust the speed sensor, see the diagram attached, clean, and tight the wires connector very well. 2) Test the input voltage motor, if there are the motor need repair. 3) Tes the output voltage board, for input voltage motor, if there are NOT the board is faulty.l
After you did, RUN the software calibration for diagnose, troubleshooting,and fix it.
Sounds like the function keypad has failed or worn out from excessive use of those buttons Call Kettler's customer support
KETTLER International Inc. P.O. Box 2747 Virginia Beach, VA 23450 USA
Tel
(757)427-2400
Fax
(757)427-0183
Email[email protected] or www.kettler.co.uk
