TP-LINK TD-W8901G Router Logo
Negm Shams Posted on Feb 11, 2014
WIRELESS DOESNOT CONNECT - TP-LINK TD-W8901G Router
5answers
Wireless Connection to the Internet
Hey mate,
So looking at your pda - it has no wlan build in, so you would need to get a wireless adapter for it.
Its pretty simple, install the adapter, plug it in, setup the wireless details of your home and your set to go.
Internal error has occured 80410a0b psp1001
try rebooting and restoring the defaults and after that empty the network connection and install the connection one more time and connect to the wireless connection and save and test connection and if it says sucess your back online and if doesnot says succes and says failed (sometimes it may also work)and the VOILA
Laptop doesnot recognise my router Desktop works fine connection is from cable modem to router. rouer to desktop.
Try changing channels on the wireless tab in the router. On most routers the default wireless channel number is 6 and you and your neighbor could be sharing tha number. Go to channel that is avaiable, I myself had that trouble myself.
I had channel 11 set and someone got the internet and mine was having trouble so I done a scan and found 3 was open and I have no problem since.
2helpful
2answers
Unable to establish a wireless internet connection
Does your computer normally recognize other access points? Example, free wifi in some bookstores in fast food restaurants. If it does, check and make sure the wireless router is on. Also, plug the PC into the router with a network cable, determine the gateway IP address, enter that into your browser, and make sure the SSID is being broadcast. If you don't know how to do this, the following links may help:
http://wiki.answers.com/Q/How_do_you_find_the_gateway_address_and_subnet_mask
http://support.dlink.com/supportscope.asp
The d-link support will help with your specific router.
Won't turn on..
Take off the the battery and connect the cable to your pc, and put it on, if it works this means the battery is died, if it doesnot come on try to use another charger, it seems the charger doesnot give enough power for your laptop.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Wireless broadband connection
please check if the WLAN of your laptop is set to automatic.
Top TP-LINK Computers & Internet Experts
 Mikey
Mikey
Menachem Grossman
Menachem Grossman
Are you a TP-LINK Computer and Internet Expert? Answer questions, earn points and help others
