I have 1999 dodge Durango Exhaust smell coming in from vent please help
SOURCE: ES 300 burning gas - coming out exhaust
sounds like a head gasket leak if the car is leaking gas DO NOT drive it if the gas is hitting the exhaust it will catch fire
SOURCE: Exhaust smell
What does it smell like? If it smells like rotten eggs that is a tell-tale sign that your catalytic convertor is bad.
SOURCE: exhaust fumes coming through heater vents
YOU HAVE AN EXHAUST LEAK ON THE FRONT END OF THE EXHAUST SYSTEM.GET THAT FIXED ASAP! THAT IS CARBON MONOXIDE!
SOURCE: 1999 Dodge Durango NO HEAT
Bad NEW thermostat? I had the same problem on my first generation Dakota. The problem for me turned out to be the DODGE thermostat I used to replace the old Dodge part. I went and got a Stant from local auto parts store using the standard temperature spec and quit shivering the next time I drove it. I hope that helps!
SOURCE: air not coming out of any vents of my 99 dodge durango
If on either heat or AC your not get'n any air out of your vents but can hear your blower motor turning then i would say you need to replace your cabin filter.. it filters the air inside of your vehicle
