My printer won't turn on, i went to the printer folder thing and right clicked my print to use on line but got the error Operation could not be completed( error 0x00000005) Acess denied. I restarted my computer, i went to admin tools, services, print spooler off then on. Nothing seems to work. I have a vista.
When you click 'print' on your computer, change the printer-settings to "double-sided" or "print on both sides", and then click OK. The printer will do the rest.
Disconnect and reconnect the USB Cable. and then try this:
Solution 1 On the Computer:
Click Start and then go to Printers and Faxes (XP), Printers(Vista), Devices and Printers(Win 7)
1. Right Click on your printer Icon
2. Click Open or See What's Printing
3. Click the option that says Printer on the upper left corner of the window that pops up.
4. Make sure the only thing that is checked under that menu is Set As Default Printer.
5. If Use Printer Offline or Pause Printing has a check mark. Uncheck it.
Try printing again. I hope this helped.
check that the printer is turn on, if on turn it off and on again, secondly check by double clicking the printer icon on your pc start bar i,t will open a pop/dialogue box, click on file and see if the offline is tick if so disable the tick.
hi friend this is very common problem for f300 series PSC
just delete the printer from printers and faxes and reboot the machine it will install printer again
there is funny thing abt this series it is saying offline when powered on and connected but when you disconnect iit will say "offline-use printer offline"
there
offline"
offline means that you have it not in line ..open your start button(bottom left of screen) then settings, then control panel will appear...directly under that is a line that says Printers..click on that..it will open up another panel..find your printer.
right click on your printer, and select use online
> start-->run, type services.msc
> double click on print spooler and click on stop and then click on start. press ok and close all the windows.
> unplug the usb cable from the printer
> now go to control panel and open printers and faxes.
> right click and delete all the printer icons related to hp deskjet f300 series.
> now plug the usb cable back to the printer
> wait for few minutes while it installs the driver automatically.
> thats it... now try printing
perform the steps below if the Operating System is XP
Step 1: ===== Determine if the printer is paused or offline : =============================
1.Open the printers folder, if necessary. a.Click the Start icon. b.Click Control Panel. c.Click Hardware & Sounds. NOTE: This step is not required when using Classic view in Windows Vista. d.Click Printers.
2.Right-click the name of the printer and then click Open.
3.Click Printer.
4.Verify that Pause Printing and Use Printer Offline are not selected.
5.Press Esc to close the window without making any changes.
Step 2: ===== Check for the default printer and USe printer Online in the printers and faxes folder. =========================================================
Click Start -->> Control panel -->> Hardware and sound-->> Printers-->>Change default printer. ---> Please Right Click on the printer icon which has tick mark and Select the options Use printer Online and Set as Default and also Select the option Resume printing.
my deskjet f300 series is erre and a lamp oronge
