If the other one is working then there is something wrong with the wireing between the two of them, or the connection in the light or the bulb contacts are dirty in the holder.
U hear alots of clinking too,when tv power on and the projection lamp tried to come on?Yes,tv have a problems with it board call the Ballast board also.This Ballast board only job is to help ignite the tv projection lamp.
Yes,if "LAMP" LED light indication front bazel panel,flashes or stay on.The projection lamp life is over.Require changing a new projection lamp.But if u also hearing clickings sound too?The board call Ballast board also dead.This Ballast board help to ignite the projection lamp.If a power supply board problems,only power light LED indication will flashes.
if you're lucky it's just the bulb who has burned out. If not, and if it implies the power source, it will be expensive to repair. Start by checking the bulb - take it out and check it with an ohmmeter.
When u turn the tv on,u hear alot of clicking?That mean the Ballast that help the projection bulb to work is dead.Change the Ballast,might as well change the bulb too.U don't know what is the condition of the projection bulb in.
Ur tv LED light indicator "LAMP"flashes?Then the projection bulb life is over must be change.This tv been watching the tv at least 4 or 5 hours a day,the last 3 years?The projection bulb only last about 1500 hours.
wine you trun it on do you hear eny noise comeing from the back of lamp.you should hear the lamp balstor a biz nose if you don,t the lamp power supply need to check.
The clear bulb located back left side needed to be replaced. Too much heat causes the bulb to burn out. Simple fix. One screw to open door to bulb compartment. Two screws to remove bulb assembly. Thank goodness for extended service warranty which paid for it. This is the second one in three years. At the price of $200 for bulb and $100 for trip and labor, this is not an inexpensive fix. Anyone purchasing a projection tv should get an extended warranty.
