SOURCE: panasonic cordless phone model kx tg3521 is keypad
panasonic cordless phone model kx tg3521 keypad locked .I can attend incoming calls but I can't do outgoing calls .its say dial is locked
SOURCE: HOw to unlock outgoing calls
The System Manager's phone can unlock your extension. Since it's an open forum, the exact instructions will have to be found in the User's manual of the TD system or from your dealer. The unlock code will work for all phones.
Carl
SOURCE: My Panasonic KX-T7730 is coded lock for outgoing
Now here's a question for a public forum. Who locked it? Is it outdial restricted in that you have a flashing light, or is it electronic station lock?
Both of these cases are covered in the Administration manual.
Carl
SOURCE: I'm using Panasonic KX-T7730. and
In programming you can set up Forced account codes for Local, Toll, or All calls. The extension is flagged in program 605 or 2.1 of the system and the codes are put in 310 or 1.5. It's one of 2 ways you can do it, you can also change Class of Service on each phone to deny them access to certain numbers.
Keep in mind that this is programming for a TA-824 release 3.0. We know loop start CO lines and no ISDN or BRI. Your system may be different.
Carl
SOURCE: i want to lock the
Lock? As in restrict dialing? It's done through system programming in the specific cabinet. In a TA series, it requires a bit of studying and reading to understand TRS and COS setup. There's also a dialing restriction option that can be used as a 4-digit security code before you can dial out on a line, but once that code is broken, you can compromise the system.
Carl
