bosch wfd 2473 washing machine it will not pump or spin
This video will show you how to change the pump washing
machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE
question.
And don't forget to like us on
facebook
Needs to drain 1st then spins after this if not draining .Clean filter take out small hose next to filter to assist in removing water 1st if drum quite full ..Then clean filter this should cure,,,
Isolate power and water supply and gain access to the main drum motor. Check for condition of carbon brushes by removing them and repla
ce if severely worn. Check wiring loom around motor and right back to module controller. The clicking is obviously power being supplied to motor via the loom to the motor. finally check for any dry solder joints or burnt areas on the circuit board controlling the motor.
I would say it is the rear drum bearing which needs replacement. This is what supports the load of the entire drum. The seal is just a water seal.
The good news is that it's a bosch, and replacements are easily available. You are lucky to get 7 years use without problems. Cheaper models give up after 12 months!
Check online for spares under the model number, or have it replacd by a local technician. It is the main drum bearing you need.
If this assists to a solution, Please take a moment to rate as fixya! Thanks.
