Electrolux EIFLS55IIW Logo
A
Anonymous Posted on Feb 11, 2014
Error code 21 machine does not run
Error 21
2answers
My washer has the code F 21 can you tell me what the problem might be??
I'd check owner's manual, or Mfg web site for your model.
1helpful
How do I run diagnostic test
Washing Machine Diagnostic Test & Error Codes (Cabrio ...
? 1:29
https://www.youtube.com/watch?v=yoCTzbl4FPs
Nov 22, 2010 - Uploaded by applianceassistant
Washing Machine Diagnostic Test & Error Codes (Cabrio, Bravo, ..... What can i do? ... I tried to put it in ...
Fix and Diagnose Kenmore Oasis / Whirlpool Duet hE Washer
? 7:21
https://www.youtube.com/watch?v=8Z1JdsJYa14
Apr 24, 2011 - Uploaded by Alprazolam
Tried to do the diagnostic test and it still won't do anything. ... If the latter, and it won't run any diagnostics ...
How do you do a diagnostic test for a Whirlpool Cab
Hi Washing machine BOSCH Maxx 7. Displays error F 21. What's wrong - and what can we do ? sincerely,Jette
The F21 error code indicates that you have a problem with the washing machine's motor.
Have it checked out by competent electrician.
What does the error code F 21 mean
F 21 indicates a drain problem.... mostly due to a clog. Google
washing machine F 21 code. There are many links including
repair videos. Good luck to you.
Regards,
Dennis
Error code 5d or f-21
LONG DRAIN
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:
After 4 minutes the "Sd" error will be displayed, then 4 minutes later the "F/21" error code will be displayed.
Press PAUSE/CANCEL two times to clear the display.
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Maytag washer throwing fault code 21
An "F21" or "F02" error code is indicative of a slow draining cycle, normally caused by a clogged or kinked drain hose. If an "F21" or "F02" error code appears, check the drain hose on the back of your washer to ensure that it is not clogged or bent. Once the drain hose has been unblocked, the error code should disappear and the machine drain properly. However, if you have a high efficiency washing machine and the error code continues to appear, make sure you are using the correct detergent; because high efficiency machines use much less water than traditional washing machines, they require the use of a low sudsing detergent. Traditional detergents may produce too many suds, which can block the machine's drain hose and lead to slower draining cycles.
2helpful
F-21 error means What?
F-21=LONG DRAIN If the drain time exceeds 8 minutes the water valves shut down. After 4 mins the Sd(slow drain) error will be displayed, 4 mins later the F/21 error code will be displayed.
Press PAUSE/CANCEL 2 times to clear display
Probable cause/Proceedure
Drain hose plugged/kinked
unplug washer/disconnect power
check electrical connections to pump
and make sure pump runs
check drain pump filter for strings,sand etc
plug in washer If this dont work
replace pump.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
1helpful
Error code F 21? washer stops
Hi
The error code F21 means LONG DRAIN
NOTES: After 4 minutes the “Sd” error will be displayed, and then 4 minutes later the “F/21” error code will be displayed. Press PAUSE/CANCEL two times to clear the display.
Possible Causes/Procedure
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
1helpful
Error code F-21
Hi there, I think the first thing you need to do is check the pump and make sur ethe impeller inside the pump is actuall turning and in good shape. Something may have passed through and in the course, sheared off the impeller fins. Chekc closely... Thanks
Top Electrolux Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
