Question about HP Photosmart C3180 All-In-One InkJet Printer
HP Photosmart C3180 prints a solid black line left side of paper ONLY when you COPY. When you print from computer, it prints just fine. It is only from COPY mode that the solid black line appears.Already calibrated, re-aligned it, and so on. It is an Apple item
Unfortunately, your C3180 printer needs some repairs done to it or you . A section of the printing arm that does the printing is faulty. This happened to me and apart from replacing the arm (at considerable cost) I purchased a new printer at a much cheaper cost. You can use your faulty printer for printing from the computer but not for copying or scanning. MG
Posted on Jun 18, 2009
SOURCE:
How do I get rid of shadows on my printing from my HP Photosmart C3180 printer? There is an extra shadow behind EVERY single piece of text. It makes the whole page look blurry. It isn't as if t
I have a Canon printer. Whenever pictures or text gets a double or blurry image I open the printer solutions menu. It sounds as though there is a problem with inkjet alignment. By clicking the realignment button the printer will automatically realign the jets. I usually test the alignment by printing a page from that program. All the line segments should line up.
Jan 01, 2013 | HP Photosmart C3180 All-In-One InkJet...
Region codes for France for a photosmart c3180 all in one
Well I had the exact same problem with a C3180 bought in the USA and I moved to France. I called the HP tech support and after I bought 5 brand new cartridges upon their recommendation we haven't been able to print the 10 tap test page
I recommend that you try doing that before you call them otherwise you will be wasting your time
To print the 10 tap test page you need to press simultaneously CANCEL and START COLOR COPY. I couldn't print the 10 tap test page because the printer will not recognize the cartridges bought in France (START COLOR COPY and START BLACK COPY blinking + E in front of COPIES)
If somebody knows an alternate method to print the 10 tap test page, please share it as this is the blocking point with HP support
Thanks
Feb 10, 2010 | HP Photosmart C3180 All-In-One InkJet...
Mac OS 10.5.8 HP Photosmart C3180 does not print
Exactly what I'm experiencing, it goes though all the motions, but no ink is on the paper. I just installed 10.5.8 last night on my Mac Pro. The drivers are up to date, but no ink hits the paper.
Sep 22, 2009 | HP Photosmart C3180 All-In-One InkJet...
C3180 feeding paper but not printing
I ended up unplugging the unit for a few minutes. It fixed the problem...
May 15, 2008 | HP Photosmart C3180 All-In-One InkJet...
C3180 will not print as error occurs even when installed
Try printing a manual self-test page:
1. Press and hold Cancel on the control panel.
2. While holding Cancel, press Start Copy Color.
The self-test report prints, containing the serial number and service ID.
This should tell you if it is a problem with the unit itself, or with communication between the unit and your computer.
Feb 19, 2008 | HP Photosmart C3180 All-In-One InkJet...
HP c3180 inkjet printer problem
apply two or three drops of 3 in 1 oil to top of the big silver rod (inside printer cover)on which the ink cartridges ride.
UNPLUG RESTART AND Print
Dec 25, 2007 | HP Photosmart C3180 All-In-One InkJet...
Printing Problem
Go Applications-utilities-Print Set up utility Open Print set up utility Then Go reset Print system Then go to hp folder-device utilities-hp set up assistant Run hp set up assistant to install the drivers it will fix the Problem
Sep 05, 2007 | HP Photosmart C3180 All-In-One InkJet...
HP Photosmart C3180 All-In-One InkJet Printer Logo
400 people viewed this question
Clive
Clive
Thomas F. Schneider
