I had an alpine type x 10 bumpin with this lanzar when it fried. I then tried a 2000 watt at a 550 rms 2 ohm dual voice coil mtx speaker. But the mtx starts to pulse like a heart or something. I But it only occures when the gain is nearly on half. but bellow that it works. but cant get no bass. Then my friend had an mtx 4ohm speaker, and when i hooked it up, it worked just fine, even when its bridged. I was told it this amp is 2ohm stable, but i dont know how to get the 2ohm stable setup. Kinda confused
The 2 ohm stable rating on the amp is PER channel meaning that you could effectively hook up a 2 ohm speaker or a 2 ohm load to each channel without the amp getting f"d up-butin bridged mode it will only be 4 ohm stable. to achieve a 4 ohm load with your sub the type x wire the coils in series that will get you at 4 ohms to run in bridged mono .But you will get the exact same amount of power if you wire each coil to one channel of the amp as bridged mono sees the sum of your 2 ohm channels combined-Hope that helps.
