My system Nordic Track commercial zs started not displaying speed and incline at same time. Tried calibrating both speed and incline neither worked. Incline starts to calibrate but does not go full range. Replaced controller system worked for several minutes. Then problem occurred again. Any ideas?
Sounds like your console. Being that it’s a NordicTrack it’s not worth repairing.
Proform Treadmill Incline Problem Fixed How to reset re calibrate your treadmill
Please see this video for to help you to fix it in incline and calibration incline motor
Blessing
[email protected]
cell+whatsApp: +50588611441
SOURCE: Just replaced the motor controller on my treadmill
You have one of three things wrong. Either a bad console, bad motor or a bad wiring harness.
If you have a flashing light on the controller when you attempt to start the machine then you more than likely have a bad motor. (this has a long warranty may be able to get one for free, check the back of your manual)
If there is no flashing light on the console then you will need to check the wire harness. This unit is known for pinching wires at the lower section where the upright connects to the lower frame. To check this you will need to remove the console. Three screws on each side and the wire harness on the right side will need to be unplugged. Then remove the right upright by removing the two bolt located on the bottom of the frame. Then do a visual inspection for pinched wires especially where the upright connects to the lower frame.
If the harness looks ok then you will more than likely have a bad console.
If you need parts you can go to http://www.iconservice.com/CustomerService/parts.do
Good Luck! Tim
SOURCE: Nordictrack COmmercial 1500 console buttons don't work
http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitnes
sincerely. Please keep me in touch.
The Steps for Newer Style
Console Calibration
1.
Locate the calibration area on
the rear or underside of the console (a hole, near the console's center, that
goes through to the electronics board. (This hole should not have a
screw in it.)
2.
Insert a pencil (eraser
end), into the hole and feel around for the cal button (will click when
pressed).
3.
Press the button 2
times (with the pencil eraser). The first click should show CL11 in
the console, the second click should show CL21.
4.
If the process was done
correctly, and CL21 appears in the console, you are in "calibration
mode." The next few steps consists of pressing buttons on
the console and observing settings. This will not require any other tools.
5.
Press ENTER. CL22 should
display in the TIME window and (??) in the SPEED window.
6.
Press ENTER. CL23 should
7.
Press ENTER. CL24 should
8.
Press ENTER. CL25 should
9.
Press ENTER. CL26 should
display in the TIME window. You should then see the letter
"E."
10.
Press ENTER. You should see
"SS" or "55" in the console.
11. Push the STOP/START button. For safety, at
this point, you should step off, or be off, the treadmill.
12.
Push the ENTER button. The
walking belt should start to move, accelerate to maximum speed, then stop on
its own.
13.
When the belt stops, the
incline should self test by raising to its highest incline
position, then lowering back down to its lowest position.
14.
Once the incline test is
complete, push the POWER button 2 times. The unit should shut off and the
console should go completely blank. If this happens, the
treadmill is done calibrating and is ready for use.
15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
