2004 Buick Century Logo
g
guy r gobind Posted on Feb 10, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The vehicle is 2004 buick century. sometimes the temp guage rises and comes back down. during this time, clod air blows. sometimes the temp guage is 1/2 way and cold air blows. thermostat has been changed. I am not loosing cooland. why is this happening?.
  • 3 more comments
  • guy r gobind
    guy r gobind Feb 10, 2014
    how long will it take for a response? just asking
  • Bob MacDonald
    Bob MacDonald Feb 10, 2014
    Did you check to ensure you installed the correct thermostat? Is it a factory/OEM t-stat, or aftermarket? Are you using factory/OEM-advised coolant?
  • guy r gobind
    guy r gobind Feb 12, 2014
    the thermostat is from gm dealer and the coolant is DEX-Cool, Orange in color.
  • guy r gobind
    Add a Commentometines the overflo tank is full. Some
  • guy r gobind
    sometimes the hose from the t/stat to the rad (top right hand facing the car) is hard and hot and sometimes is is cool and soft. Took it to a shop and $600 LATER, THE PROBLEM IS NOT SOLVED
Lewis Meyer
Level 2:
Scholar:
New Friend:
  • Expert 140 Answers
  • Posted on Mar 21, 2014
Lewis Meyer
Expert
Level 2:
Scholar:
New Friend:
Answers
140
Questions
Helped
36067
Points
304
Is your electric fans running constantly. and most times then not you`ll need a water temp sensor or water temp relay. usually the temp sensor on that model comes usually next to the thermostat with a little wired plug on top. or on the radiator. either way pull the plug while the motor is cold. unscrew the sensor and screw the new one in and replace the electric plug back on top of the sensor. 2 things: Cold motor, have every thing set up and ready because when you take out the sensor the coolant will start to come out. you will not loose much if you work quick. keep rags or paper towels below the sensor to keep coolant off the motor and smelling when it gets hot. you have also pour or hose off coolant after your done installing the new coolant temp sensor.
3 Related Answers
6bta
  • 400 Answers
  • Posted on Jul 01, 2009
SOURCE: 2000 buick century blowing hot air on one side and
The temperature actuator has gone bad. You will need to replace and have it recalibrated. You could try and disconnect the battery for a few hours and see if it will reset it's self. But you will be in the same boat before too long. And will eventually need to replace it.
Robert Lemon
  • 108 Answers
  • Posted on Nov 19, 2009
SOURCE: blowing cold air via the heater
Assuming that none of the Electrical/Electronic controls were disturbed when changing the Thermostat it seems to me that you have an "Air Lock" within the heater. One must purge all the air out of the cooling system as close to the highest point as possible after the system has been partially or fully drained. Most of the time one will find small BRASS Bleeder Valves located somewhere near the highest point. Open each one while the system is pressurized and let Air escape until some Coolant escapes. Sometimes it may be necessary to loosen a Heater Hose and bleed the air at that point. Remember that the system MUST BE PRESSURIZED to accomplish the Bleeding of Air. Many auto parts stores sell hand pumps with a pressure gauge for this purpose and leak testing. These pumps typically replace the Radiator Pressure Cap temporarily. The system does not have to be at normal operating temperature to bleed the air out. Once the Air has been bled you will have to refill the radiator to normal full and make sure that the Coolant Recovery Tank level is also brought up to recommended level. A quick check is to remove the Radiator Pressure Cap, Start the Engine, Rev the engine suddenly (A short Jab) and see if the coolant level falls rapidly in the radiator. If it does it is definitely an AIR LOCK situation.
Fastest Robe
Testimonial: "Thank you, I'll do the quick jab test to determine the air lock and proceed with bleeding"
Anonymous
  • 1586 Answers
  • Posted on Dec 11, 2009
SOURCE: 2000 buick century, where is the thermostat
The thermostat is in a housing on the engine. It's located where the lower radiator hose attaches to the engine. The coolant level should be right near the top of the radiator when you remove the cap, and the overflow canister should be filled to the indicated line (there are markings on the canister). If your gauge stays on cold, you may have a faulty coolant temperature sensor. If it will get to normal operating temperature while sitting still, but starts cooling down when you drive, you have a thermostat failure - it's stuck open, and will need replacement.
Testimonial: "thank you for your quick response. hopefully i can now correct the problem."
98 century. temp guage is pegged out when cold & drops down when warm.
  • Wiring back to front or shorting somewhere? Possible that the temp sender unit is faulty.
My car is a 2004 buick century. Sometimes I get cold air instead of heat and sometimes the temp guage climbs. why is this happening?
Could be air pockets in the cooling system if it is not full of liquid coolant, or a problem with the thermostat.
2helpful
I have a 1998 Buick Century and recently my temp gauge was spiking close to the red. It never actually overheated and after pulling the vehicle over for a few minutes the thermostat opened up draining my...
when the thermostat opened where did the coolant drain to? not understanding. did you put the thermostat in upside down blocking the cool will cause heater to blow cold air. if not, could be radiator itself.
5helpful
Fans not working when buick century 99 engine heats up
i have a 99 buick cenrty first off the car drives fine down the road at its normal temp if you sit at a redlight to long it goes up and will not come back down untill you get going down the road. second i noticed that the fans are not coming on when the temp rises. is there anyone that can help me out on this?
3helpful
2000 Elantra Overheating
First when vehicle is cold like in the morning check and make sure that the vehicle has enough coolant/ antifreeze in radiator and reservoir. If coolant is need use a 50/50 mixture of water and antifreeze. You will need some time to do this let car run at idle until the temp guage is in the middle NOT+ normal operating temperature. At this point if the thermostat should be in the open position. Let vehicle run and check to make sure that radiator fan comes on. This should come on when guage is about midway/half way. If temperature rises above half going to h/hot and fan doesn't come on, you either have a BAD FAN BAD FAN SWITCH BAD FAN RELAY OR BLOWN FAN SWITCH FUSE. You will need to check all of the following I will help if its needed. If fan comes on and doesn't go off and vehicle continues to get hot even with fan running. Feel radiator hoses and see if the lower radiator hose is cool/cold. If it is you have thermostat that stuck closed. Replace thermostat and fix problem. If all the above is good and vehicle continues to over heat. THE BAD NEW IS THAT YOU MAY HAVE A BLOWN HEAD GASKET /CRACKED HEAD /BROKEN WATER JACKET. Basically you will need a HEAD JOB at least a head gasket. ONe tell tail sign of this is oil looking like milkshake/chocolate milk-a creamish while residue in oil or antifreeze. Contact if you need hel0p. Good Luck and thanks for using FIX YA
3helpful
Heater blowing cold air Buick Century 2000
does the car not heat up in general? Whats the temp gauge doing and how long of a ride have you tried this for?
2003 century temp guage quikly goes to hot and back to norm
You need a new thermostat. These are cheap, but can be kinda difficult to change on some vehicles. Most of them can be done very easily though. Good luck hope this helps.
Sincerely,
JC
3answers
1994 Century Buick Heating problem
did you make sure you got it full of coolent? i am saying this because if you don't it will create an air pocket in the system and it will not throw any heat until you get the air out. on some models there are relief valves either on the thermostate housing or buy the water pump to do this. all that needs to be done is to start car and let it run a few minutes to get warm and open the valve and let the air excape whenyou see a steady flow of coolent close valve and you should have it.
Top Buick Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Buick Expert? Answer questions, earn points and help others
