SOURCE: wd scorpio blue 160 gb
Reset it or format it ? cause there is no reset for hard disks.
Is your hard disk operational ?
SOURCE: is it a common issue
you could run the chkdsk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to recovery any bad sectors and automatically fix any corrupt files on your hard drive there are many ways of running the chkdsk utility
click start righy click on my computer you should see your drive select properties click tools check now tick both boxes automatically fix files and scan for and attempt recovery on any bad sectors or you could tick one box and wait until its finished then return and tick the other box
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start tick in two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
then defragment your hard drive also download and run a registry cleaner cc cleaner is 100%free
http://download.cnet.com/ccleaner/
hope this helps
