Oven and broiler not working but stove top works fine. Press "oven" button, set temperature, and it flashes for 5 to 10 seconds, as it normally would until up to temperature, then resets back to 100 degrees. Neither igniter gets hot and the shut off valve on the pressure regulator is in open position.
SOURCE: GE spectra xl44 - Oven not working, broiler & stove-top burners fine
replace the ignitor for the oven. it's the lower one and not the one on top.
SOURCE: ge gas/prop stove bottom oven burner will not
you will neeed a new ignitior
its a pretty easy repair
take out the racks
take out the bottom of the oven
you should see the ignitor
pull ou the drawer you will see the connection
disconnect it
make sure your very careful with the new one they are very brittlle
SOURCE: broiler and top stove burners work, but oven doesnt
Your glowbar ignitor for the bake burner is bad.
Use the attached diagram to show location.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5221257
SOURCE: I have a GE JGSP33
Yes, your oven igniter is bad here is the part#WB13T10001
Have a great day!
Testimonial: "g"
SOURCE: GE GAS STOVE XL-44 [?17B034]
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
