It could be just a lead, check your lead heads and inserts are clean.
Check along your leads and wires for any obvious kinks / tight bends / cuts / nicks / something sitting down on it or any damage to the wires.
It could be there is another electrical device nearby interfering at a electromagnetic level.
It could be just the dials / knobs need taking off and cleaning in behind. the pickups, you may not need to remove them just spray with electronic cleaner this stuff is great for lots of different electrical cleaning problems.
Good luck
Testimonial: "I didn't even think of the electromagnetic interference...I will definitely check that next time I'm home in about a month. Thanks for the suggestions!"
SOURCE: surrond sound
For Stereo Mode (Front L & R Speaker), you must plug RCA cables (match up red and white) from Output on DVD player to DVD Input on the back of the receiver. Then with speaker wire, run from receiver speaker output (Front Speakers) to designated speaker (make sure + and - match up to both input and output). As for hooking up surround sound, I'm currently trying to figure that one out with just using the L, R and Center. I don' t want wire running all over the place just for rears. Hope this helps
SOURCE: klh model 52 audio receiver
Open the receiver and locate the potentiometer for the volume. There should be small openings in which you can spray electrical contact cleaner. The spray can be found at any electronic supply store (Radio Shack). Make sure the product says no or zero residue. I use a product called "Electrosolve". After spraying, immediately rotate the pot back and forth a few times. You may need to repeat this process two or three times. You might as well hit the other controls while you're at it. If several attempts don't eliminate the problem, the pot will need to be replaced.
SOURCE: connect R5100 to DVR/Monitor
use component audio to the HDTV and optical audio to your KLH reciever. The component and optical are always active at the same time. I work for TWC if you have more questions.
SOURCE: why do i have static and then no sound ?
Hi...
You have a faulty reciever.
Take it back and get another.
No sense in going any further.
SOURCE: klh audio video R5100 surround sound receiver
could be 2 things....
1) The receiver could be set to feed the right speaker with more volume. Check the volume setting for each individual speaker on the receiver.
2) The cable connecting the left input from your dvd player is not connected properly or is bad. Try swapping the left and right audio input cables to see if this moves the problem to the other side. If it does - get a new cable.
