Question about Canon PowerShot Cameras
Canon PS A650 IS: LCD blank
When switching on the camera, the LCD becomes a little bit light (does not remain completely dark) but no image or anything else like an error message can be seen neither in playback, nor in shoot mode. It is also not possible to shoot any images. If I press the Menu button or switch to shoot mode, the LCD becomes a little bit more lighter, so something seems to happen but the LCD still remains blank! For some time, I've had some problems using the mode switch: it would remain in playback mode even if switched to shoot mode. So I struggled to put it in shoot mode but finally I always manaded to do that. Whether this has anything to do with my new problem of blank LCD though?
SOURCE:
How can I get camera and laptop to communicate?
When you purchase camera, there are probably a usb wire to help you connect camera with laptop. You can find it or buy another one from ebay.
May 02, 2015 | Canon PowerShot A650 IS Digital Camera
No image is captured by the screen itself (LCD screen works but completely dark).
Did you try pressing the display button several times? in both viewing mode and record mode? Cycle through all display modes, s you get used to the button, so it does not trow you off when it happens again.
Feb 16, 2015 | Canon Cameras
The camera won't register an image to take a picture of.
LCD monitor electric film contacts must be fixed. If you can not do it yourself then please contact with the nearest authorized Canon Service. I think it is too easy to fix it so it is not need much money.
Feb 28, 2010 | Canon PowerShot S2 IS Digital Camera
Pictures turning out dark, LCD not adjusting
CCD sensor problems usually present themselves as either a blank image, purple cast, or lines through the image. Incorrect exposures are usually a result of the lens shutter failing to open and close correctly. Typically, the lens is not servicable and they need to be replaced.
Apr 13, 2009 | Canon PowerShot A95 Digital Camera
Blank LCD on A650IS
if ur pics are ok and ur lcd is faulty only then u can do it
here u go u can buy and replace it is easy to do so but u can get it fixed as well see the link and pls rate me FIXYA for help
http://www.darntoothysam.com/servlet/the-1222/Canon-PowerShot-A650-IS/Detail
Mar 27, 2009 | Canon PowerShot A650 IS Digital Camera
Lcd Screen brocken
It will cost u around Rs 3000 in Indian Rupee , and USD $50 if u get it from states
Oct 23, 2008 | Canon PowerShot SD600 Digital Camera
Wide lines and dark shadows on some pictures
There was an issue with some of the A650 IS cameras that bright light or sunshine could sometimes enter the case and create such symptoms as you're describing:
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=183&modelid=15658&keycode=2112&id=39151
Although your camera is not an A650, recommend contacting Canon, especially if your camera is less than a year old, to have it repaired under warranty service. Even if older, recommend contacting Canon anyways to argue free repair if your symptoms match that of the above link. Call 1-800-OK-CANON.
Jun 28, 2008 | Canon PowerShot A710 IS Digital Camera
Image download issues-Canon A650 & Windows Vista
oh my GOD Same problem with Sony Cyber Shot DSC-W35 !!! photos splitted into 3 parts vertically or horizontally, i don't know why
Dec 26, 2007 | Canon PowerShot SD550 / IXUS 750 Digital...
LCD is Blank when Camera is on.
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Dec 16, 2007 | Canon PowerShot A75 Digital Camera
Colour banding on 10D images
Shoot in RAW mode and convert to 16 bit images to reduce banding
Sep 14, 2005 | Canon EOS-10D Digital Camera
Cameras Logo
64 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
