SOURCE: Detuning of Akai EWI 4000s
Are you shure that you aren't touching the bend up plate with your right thumb? This isn't easy detected by sax players which are used to have a thumb rest at exactly the same spot where the bend up plate is. You might switch it off (see manual). With the bend up plate on you should aways use a tight strap which helps a bit to not touch the bend up plate accidentally. I'm still struggling with this occasionally.
SOURCE: EWI won't respond to comands
I've got the solution.
Turn the EWI off.
Press the LEVEL, FX, SETUP and TRANS buttons all together.
Turn on the EWI.
This is a Reset to Factory Preset.
Greetings Fred Roubos.
SOURCE: I installed the Vyzex program
I think it is a compatibility issue of th program ...with the new operation system that were developed in the past 2 years..try to get on the program's site ..and see what they have in matter of updates and about the compatibility with the operation system you use.. If there is non ...than if you know it worked on windows XP...just scarify a partition and install windows xp on it ..and go for a dual boot ..when ever you need to use it ..boot into xp...and in rest use the computer normally
SOURCE: I own a EWI 4000s
Test it with batteries to see that it works, if it does, then you probably have the WRONG adapter.
