2005 Cadillac CTS Logo
m
marisela Posted on Feb 09, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code Po496 cadillac CTS
What is the code so i can fix it
Michael Carroll
Level 3:
Master:
  • Master 742 Answers
  • Posted on Dec 16, 2014
Michael Carroll
Master
Level 3:
Master:
Answers
742
Questions
Helped
171248
Points
1973
The P0496 DTC code is a generic code which applies to all vehicle makes. A quick search on the 'net shows that this code seems to be more common with GM
3 Related Answers
Anonymous
  • Posted on Sep 18, 2009
SOURCE: CD Mechanical Error on 2003 Cadillac CTS
take the radio apart and take them out one by one, i just fixed my yesterday
Anonymous
  • Posted on May 25, 2012
SOURCE: I have a 2005 cadillac cts with 90,000 miles and
I've been having hesitation with shifting for the past 3 years. been in the shop 6 times (its a 2006 CTS with 78,000kms on it).
First they replaced the torque converter. That fixed the symptoms for 6 month. then they replaced the ****** under warranty. next time it was software. next time I'm not sure what they did to fix it. This time they blamed it on timing chains. After being in the shop for 8 weeks, I picked it up today and it worked great, except the check engine light came on, drove it straight back to the dealer. they took it for a test drive and it broke down on the highway. had to be towed back in.
My guess is you have the "stretched" timing chain issue that can occur on the Cadillacs. It might be covered by warranty, or if your SOL like me... not covered under warranty. Right now I'm fighting with GM Canada and the local GM dealer to fix this under warranty since it started under warranty to begin this.
Denny Giesel
  • 818 Answers
  • Posted on Oct 11, 2013
SOURCE: what does code po496 mean on my cadillac sts 3.6l
your evaporative emission canistor solenoid purge valve is either stuck open or shut and needs to be replaced-auto zone pep boys or advanced auto can hook up diagnostic and confirm for free-cheers Denny
2answers
03 Cadillac CTS I got a message coming up on the radio that says service vehicle soon what made that mean
3 post 1 car ,and now answered 3 times
your other posts show 03 Cadillac CTS , <<< this? is the car? or posting or 2 cars? IDK with double posts what's up?
no VIN told to know what engine is there.
3.2L v6? LA3 caddy<<<< THIS? IT IS and engine problem, so?
hOW MANY MILES ON THIS ENGINE?
EVER CHANGE OUT THE CAM BELT, THEY ARE last from 60k to 100k MILES AND THEN SLIP. cam TIMING,
the problem is easy, most times, this belt on the cam died, ran to 100k miles they die.
lack of proper service is the cause
and cam sensor fails. even replaced 10 times as is must timed wrong.
here is the long answer the full procedure told
40 steps.
https://www.justanswer.com/cadillac/64zgn-cadillac-cts-ok-goes-03-cts-3-2l-threw.html
and on the rell Cadillac for this key FACT
To answer the OP's question, yes the 3.2L is an interference motor.
that means if engine is cranked or run with belt slipped or broken, the valves BEND
and a cylinder leak down test fails (hand turned)
What does a po496 code mean? why is engine light on? When I purchase a gas cap will this solve the problem? How can i fix it without seeing a dealer? 2006 cadillac cts 3.6 engine
The code insinuates that your purge valve has problems and probably needs to be replaced. Rather difficult to explain the repair but I did manage to find what you need to do on video.
https://www.youtube.com/watch?v=08R_-QFGpDM
1helpful
Is there anyway to get cds out or fix a 2007 Cadillac cts 6 cd changer reads "CD Mech error"?
you will have to remove the CD changer and on the back should be a cassette release button , that will get the cd's out, as for the error message i would expect that it will need to be repaired or even replaced , hope this helps
2helpful
2006 cts cadillac po496 code
Trouble Code: P0496
Evaporative Emission System Flow During Non-Purge .This is what is listed.
Check engine light up
DTC P0496 - EVAPORATIVE EMISSION (EVAP) SYSTEM FLOW DURING NON-PURGE
SYSTEM DESCRIPTION
This DTC tests for undesired intake manifold vacuum flow to the evaporative emission (EVAP) system. The control module seals the EVAP system by commanding the EVAP canister purge valve Closed and the EVAP canister vent valve Closed. The control module monitors the fuel tank pressure (FTP) sensor to determine if a vacuum is being drawn on the EVAP system. If vacuum in the EVAP system is more than a predetermined value within a predetermined time, this DTC sets.
THIS CODE ID FOR A 3.6L engine
2helpful
Show engine error codes on display 2006 Cadillac CTS
Unfortunately not. This vehicle has a very sophisticated CPU and the old age tricks will not work on this particular design. You will need to gain access and allow a professional GM tech to pull the Cadillac codes. An ordinary code reader may miss the exclusive Cadillac codes that may be stored at any given time.
A certified GM/Cadillac code reader will be your best bet..
2helpful
Top Cadillac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Cadillac Expert? Answer questions, earn points and help others
