Hi I have a candy grand Go 1682 and I think there maybe a programming fault. It seems to get its self confused in a normal wash mode. It starts by let water in then starts the cycle, heat the water and starts washing, but then it'll stop, then start to spin for 2 seconds, then stop for a minute or two, then spin again for 2 seconds, then put more water in and just keeps doing the same thing untill you stop it. Any suggestions please
SOURCE: Wash starts it fills with water then stops and wont wash
problem may just be that drum is not turning so you think program is stopped. try cancelling and select spin program and see if you get spin
SOURCE: Neptune MAH3000AWW will start to fill when start is pressed, but stops seconds later
either a faulty pressure switch / pot or faulty controller - either way you will need to call someone in.
SOURCE: our hoover ultra care 1300 large load washing machine spin fault
The most common cause of machines stopping mid cycle is not draining. Your machine should have a filter behind the kick plate at the bottom.
If this is not the case please post back for further assistance.
SOURCE: nec nw-891 washing machine will not complete the programmed cycle
Apparent malfunction in the timer circuits. Specific Component replacement not available.
