SOURCE: play laptop video on tv
yes vga plays hd video. but an hdmi cable is better. get a VGA to HDMI cable
SOURCE: Do I need to do anything to my CQ60 to ensure the
You need to go into the graphics control and set your computer to use the tv as a display. There should be a shortcut key by pressing "FN" along with the "F key with what looks like two monitors separated by a / mark". Mine is F4, but yours may be different.
SOURCE: how can i connect my compaq presario cq60-215dx to
In most cases the answer is "YOU CAN'T DO THAT".
The output from a computer is not a signal that a regular TV can interpret as an image, unless your TV has an input similar to a computer's VGA or DVI port AND the TV's manual says that you can do that. Otherwise, you're out of luck
SOURCE: Im trying to connect my
Your television may have multiple HDMI ports. When going through main menu on the television, look to see more than 1 HDMI entry (typically numbered HDMI, HDMI2 etc). Try all HDMI available on the television until you see a picture of your notebook's desktop on the television.
