Some day ago my drive fall from about 2 feet, but was working well. but later days it was start reading error, then i use "chkdsk /f" command to repair its MBR.. it didnt work and make drive read only, after 3 days it stop deducting drive and giving buzz beep buzz beep buzz beep.. 3 beeps.. is there any way to get data back..
SOURCE: seagate freeagent 500g usb 2.0 beeps sound
You still need assistance in cracking open the Seagate Freeagent Pro 500GB and trying data/file recovery? If yes, would appreciate a post back.
Good luck and kind regards.
Thank you for using FixYa.
try to re-install the driver then plug it if that comes with no result u just try what the mate said google data recovery cuz i ve seen one of those hard disks its impossible to open the case without breaking it!!! they have the advantage to tell u that price but try google data recovery that is the best solution we recommand
best regards!!
SOURCE: MY SEAGATE 500GB HARD DRIVE
The disk-drive has malfunctioned.
Search online for a professional "data recovery service".
For a significant fee, they can repair your disk-drive,
just long-enough to copy your files to a new disk-drive.
If it still has a valid WARRANTY, exercise the warranty to get it repaired/replaced.
If the warranty has expired, then open the case, remove the disk-drive, buy a new "compatible" disk-drive, connect it, and thus "revive" your external storage device.
SOURCE: Hi, I bought a Seagate
Did you reformat the FreeAgent drive when you backed up the Mac? If you use Time Machine or other backup software for the Mac, you had to reformat the drive. If you want the PC to read the disc, it must be formatted in a FAT32 or NTFS file system. The Mac OS formats discs in the HFS+ (extended hard drive format) system.
Unfortunately, if you reformat the disc to a Windows compatible format, you will lose your current backup. The drive will be as a large media transfer disc but not for the backup images. This site, http://www.cs.ubc.ca/~pcarbo/macnexstar.html , has information on splitting the hard drive into two partitions, one HFS+ and one FAT32. Then you could have your backup on one part of the GoFlex and still transfer files from the Mac to the PC and vice versa.
I hope this helps.
SOURCE: I bumped my Seagate 1
In my opinion, the r/w heads have crashed on the surface or malfunctioned so that the voice coil has retracted the heads and will not allow the disk to function, thus the beeping. You have to decide if the data is worth recovering, i.e many bucks for a recovery company to get your data. If you open it up, it will allow dust in that will contaminate the data. In order to recovery the data, the disk has to be opened in a ultra clean environment and the disk taken from that drive and placed in another drives electronics and heads so that the disk will operate and your data can be copied out to another drive. As you can see it is a labor intensive process that will cost. Also the data recovery company cannot or will not guarantee success, and you still pay for them to try.
