ASUS P5KPL-AM SE Motherboard Logo
s
serdgee64723 Posted on Feb 09, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No voice in p5k pro - ASUS P5KPL-AM SE Motherboard
Iron Fist
Level 2:
Habit-Forming:
  • Expert 98 Answers
  • Posted on Feb 09, 2014
Iron Fist
Expert
Level 2:
Habit-Forming:
Answers
98
Questions
Helped
14482
Points
210
1. Make sure the internal connections of your sound device are ok.
2. Make sure you have properly installed the right sound driver(s)
3. If all the above have failed to resolve your problem, then you have to check whether something on your motherboard has been burned...
P5k-e front pannel audio not working
Make sure you check that the front audio cable is connected properly on your motherboard. You can see how it's supposed to be hooked up and where it is located on page 2-32 in either of the manuals I have linked up for you below. And if you haven't already make sure you have the correct audio driver installed.
Drivers & Downloads for ASUS P5K-E/WIFI-AP:
http://www.asus.com/Motherboards/Intel_Socket_775/P5KEWIFIAP/#download
Manual #1:
http://dlcdnet.asus.com/pub/ASUS/mb/socket775/P5K-E/e3216_p5k-e.zip
Manual#2:
http://dlcdnet.asus.com/pub/ASUS/mb/socket775/P5K-E/e3501_p5k-e_wifi-ap.zip
1 continuos bip
Check your ram modules(sticks) are properly installed.
Is Asus p5k support window 7 64bits? Anywhere I could find support or driver for Asus p5k for window 7 64bit? there isn't any at http://support.asus.com I have just upgraded to windows 7 64 bits....
Good day,
Windows Vista 64bit driver will work on Windows 7 64bit drivers. you might also check P5K Memory QVL to identify the source of BSOD or run a memtest on your memory individually.
Driver
Thank you for posting hope this helps..
2helpful
Does p5k se motherboard support with GTX460 ?
If you are talking about the Nvidia Geforce gtx 460 video card working with the Asus p5k se motherboard?! YES!! That motherboard should have a pci-e 2.0 x16 expansion slot with is what this video card needs.
Hope this helps!
Iwant my asus motherboard driver p5k-vm serial no:85moack11970 part no;90-mbb690-gouayooz p5k vm green
Here is a link to the drivers for your Asus p5k-vm Motherboard You will need to select the operating system you are using.
Please don't forget to rate this solution.
Asus P5K-e Wifi/AP audio to drive surround speakers
Since the left and right speakers sound pretty good, there is no problem with the driver software, the problem is in the sound system itself. be sure to have your sound system be check by a professional technician
Raid sys on p5k/epu
You are correct. The Asus P5K does support SATA RAID configuration. Page 4-14 in the user manual.
Congifuration [Enhanced]. Only real option is IDE. That does not mean the SATA drives will run like an IDE. The SATA's will function faster. In order to get RAID function you would need to have bought the Asus P5K Deluxe. http://support.asus.com/download/download.aspx?modelname=P5K%20Deluxe/WiFi-AP&SLanguage=en-us
Mike
Motherboard problem
Hiw can u say's its display problem,Have u checked the signals on k/b ?
If not check the Num lock status in keyboard. Press the Num lock key ,if the light glows and stands for sometime display is ok,but ur vga adapter is the problem.
Otherwise problem maybe with m/b or psu.
Pl check it.
Regards.
Was this soultion useful?give the apppriciation by rating it.
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
