My Mercedes c 240 (2002) loses power and the ESP comes on. My mechanic changed the fuel pump, catalyctic converter, and one other equipment that regulates the airflow, as well as the fuel filter but the problem persists. What next? This is really frustrating because I have spent so much money on this.
SOURCE: mercedes benz bas/esp light on
Change the brake light switch first, its on the brake pedal, £9 from mercedes.
jib
www.mercanic.co.uk
SOURCE: Replace Cabin Filter in my 2002 C240 Mercedes Benz
I have a 2002 C240 Mercedes and need to replace the cabin air filter. Problem, I don't know were it is located or how to replace it. Can you help me.
SOURCE: change air filter on a mercedes benz c240 year 2005
Open the hood. The cover on the top engine has 2 plastic parts. Need to remove the front (small) part first. Gently lift it up and pull forward. After removing the front part , you have an access to pull up the entire other part from the front and the back. After lifting it up and taking it out, put it upside down on the floor, remove all the screw to take out the old filters and replace with new ones. There are 2 filters , one is on each side. Put all the plastic parts back in reversed order, then you are done.
SOURCE: mercedes benz bas.esp light on when driving
check brake light switch and replace it, it's most common fault. is this information helped you. please vote me and leave a comment.
