Question edited for FULL 'make model (what it is)'.
Question moved from Computers to correct category.
"DATA ERROR CANCELING..."
Output was stopped because a problem was found in the data received.
Operation cannot be continued. Check whether or not there is an error in the data. Check for a problem with the connector cable or the computer, and redo the operation from setting up the object to be printed on.Roland Technical Support.
A 54.XX error is a sensor problem. What possessed you to play with the toner cartridges? Could be a thermal problem or a bad sensor. You are going to need technical help.
good day sir. i have the same problem before. try replacing the black laser. it worked for me. I simly moved one of the color
lasers to the black spot and it worked.
If the error won't go away, the DC Controller in the printer will have to be replaced. The ".0C.01" part of the error can't be found in the service manual, but I don't think that it will change the fix.
Printer errors are various messages displayed on the LED display of printers. ... We also carry a lot Lexmark Toner & Ribbons for your one stop shopping experience. ...ERROR 54 - Duplex Feed Error (IID/IIID) or Main Motor Stall 2686 A/D ..... Sharp Printer Supplies, TallyGenicom Printer Supplies, Texas Instruments ... www.printersupplies.com/errors.html
Clean the thermistor and clear the code by turning on both dip switches on the main board, turn off the main switch, turn off the dip switches, turn on the main switch.
