Refrigerators Logo
Posted on Jun 07, 2009
Frigidaire plhs267zab5 ice maker won't switch crush to cube
Frigidaire plhs267zab5 ice maker 25.9cuft side by side
Ice maker won't switch between crush and cube
  • tunemup Dec 12, 2009
    Everything moves freely, any other ideas?
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Jun 19, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2169
Points
24
Pull out the whole ice machine part. At the back of the fridge you will see a small rectangle hole with a white plastic part inside the whole. Loosen the pastic part by applying a little pressure with your fingers it should move, it's probably just sticking.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 14, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1975
Points
THANK YOU! THANK YOU! THANK YOU! Been having this problem for 4 years! Thank you ism6507!! Your solution worked!!!!! Can't thank you enough!!!!
Jerry Mortellaro
Level 1:
  • Posted on May 07, 2019
Jerry Mortellaro
Contributor
Level 1:
Answers
Questions
Helped
1975
Points
9
Ok so I'm having a similar problem, I can't seem to get cubed Ice, so I read this about sticking your finger or something into this hole in back of icemaker. Yea right this is going to fix my problem I say to myself. While I'm laughing saying again to myself, yea! sure this is going to work.... and low and behold It WORKED!!!!
1helpful
Frigidaire model PLHS237ZDBA Ice maker dispenser won't switch back to cube ice it keeps crushing ice though its on Cube ice?
The rod under the ice tray was not in the correct position when the tray was inserted back into the freezer after removal. I get cubes now.
Frigidaire ice maker always crushes the ice
Solenoid that switches blades from crushed to cubes is most likely not working and should be replaced
3helpful
2answers
Ice maker stuck on crush, continues to crush ice when cube button is pushed.
Remove ice bucket,check solonoid on back wall behind bucket may be stuck in up position pull down and recheck dispencer.
2helpful
My ice-maker keeps switching to crush on it's own.
There is a long rod on the right side of the ice dispensing bucket.
This rod goes through a hole in the back wall of the freezer where a solenoid should pull up on the rod allowing the ice cubes to dispense without being crushed.
If this solenoid goes bad or ice forms around the plunger, it cannot pull up on the rod.
Check out that solenoid and the rod assembly.
https://www.repairclinic.com/Frigidaire-Refrigerator-Parts
appliance parts, help & more
2helpful
2answers
Ice maker is crushing ice when cube ice button is on
We've had a similar problem, possibly the same, with our LG in-door ice maker. Whether cubed ice or crushed ice is selected, it crushes the ice.
We found that there is a little lever on the inside of the door, on the lower right behind the ice bin, which freezes in the down position. This is a literal "freeze up", as a block of ice forms in the little well under this switch and eventually freezes the switch in place. Since the switch needs to go up to provide cubed,.. we only get crushed. On 3 separate occassions we've thawed and chipped out (carefully) this little ice dam and gotten cubed ice capability back for a few weeks. At which point it freezes again. I have no idea why water collects there in the first place.
Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
1helpful
Ice Maker will not dispense ice cubes only crushed ice
sounds like the circuitry on your Cubed Ice button has malfunctioned. Contact the manfacuturer for a solution.
in the meantime, u can grab the Cubed ice manually.
hope this helps!
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
