Vector Spotlight - 1 Million Candles Power, Model# VEC127Y Logo
A
Anonymous Posted on Feb 09, 2014
Need a replacement charger model number - Vector Spotlight - 1 Million Candles Power, Model# VEC127Y
Is there a replacement for the 15.6 volt Craftsman charger part number 140250013 or charger part number 140287001
look on eBay. my opinion is toss it as the batteries are Ni Cad and have a short life
3answers
Tablet wont charge
you most likely need a new charging port,,,, they are available on amazon, just search for #### charging port , , #### being your model number,,,, or remove the back number and read the number on the harness for the charging port and amazon search that number,
you tube videos will show you how to replace that, if you watch the vid for replacing the screen, you will see the charging port being removed and you'll then know how to do it
Cooling fan stopped working
any 18-20 volt laptop charger should work only need correct power plug and that can be easily changed if necessary with soldering iron and volt meter. using old charger plug as replacement. volt meter is used to check out correct polarity of plug before and after you re solder plug on.generally outside is -ve and center is +ve ,alternatively go to ebay or google and type in Sony Vaio PCG 7Q1M charger,or type in part number ,or try 18-20v laptop charger, that is what I do when I need a replacement charger,cost around $10 delivered usually.
Need to know the voltage of charger for Model Z725ce. Lost charger and need to replace.
hello sir, Please provide the following information so that your issue may be diagnosed properly,what is it? brand name,complete model number The problem, What is happening with what? When it is happening? Are there times it does not happen? Did it just start happening? Did it ever work ? Did any seemingly unrelated event coincide with whatever it is not working? need the model number and brand name, if you need a manual i need the brand name and model number,if it is a riding mower the model number is under the seat.a snow blower the model number is on the rear of the machine, let me know,thank you. 11
Feb 02, 2012 • Garden
2answers
I have a toshiba laptop and I can not read the serial number on the bottom. The charger is broken. How do I know which charger to order?
There are a couple of ways to do this. First, there should be a product and/or serial number on the charger itself. You could google these numbers. Also, sometimes, when you remove the battery there is more info about the laptop. Maybe the label where the serial number is unreadable has a readable produst number example (p/n). Lastly, often the replacements from the manufacture are expensive. You can get a universal charger at someplace like Best Buy for around $60.00.
One more possibility. When you turn on your computer, it may have some information about the computer on the screen before it boots to windows. You may be able to go into setup and se the model of the motherboard which could help in your search.
I need to find where I can get a battery charger for Model # PL3-01 Motorized scooter
Is it a sealed lead acid scooter battery? Youcan get the replacement battery as per your scooters model number at http://www.monsterscooterparts.com/scooter-trickle-battery-chargers.html.All that you have to do is just search with the model number and you will getthe battery charger. Hope thiswill help you. Good Luck.
My first charger broke so i got a new one. And iv had it for a couple months and now its giving me problems... It started to not work in some outlets so i keeep having to move to new ones but then after...
I had my charger fail on me as well, I have a hp mini 210-1000. Before I threw the old charger out, I read the label on it carefully and found a replacement part. The label actually read "hp part number xxxxxx - REPLACE with part number xxxxxx." I simply searched for that part number on ebay and was able to get a reliable replacement. You probably don't have the old charger anymore. If you bought a universal charger to replace your old charger, then that could be the problem. Sometimes off the market universal chargers don't work so well in the long run. To find your charger, find out the exact model of your mini. google "ac adapter for hp mini [model number]. Once you get a part number, search for that part number on ebay. My replacement charger cost me only 16 dollars, with free shipping.
Dell studio 15 in car charger
Most ac/dc car chargers will state which models they support, by model number. I'd look at your power supply to see what the wattage rating is on yours and compare it to the replacement.70-120 is common in the replacement units.
2answers
Need power cords and phone chargers
They are available on eBay for quite cheap, I just did a quick search and they can be had for under $10 including shipping. Depends on the exact model number of your unit, there wasn't a huge selection.
Top Vector Camping, Backpacking & Hiking Experts
ZJ Limited
ZJ Limited
john h
Are you a Vector Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
