Craftsman lawn tractor model 917.250560 new battery drains quickly - not recharging from mower engine - runs only a minute or so...
It could be the stator in the engine check the voltage with the volt meter when its running if its low check connections on battery & voltage if its below 12.5 volts then its the stator but the only thing is the engine should run with-out the battery so there is something else going on there is a fuse in the electrical system if theres a short that fuse will blow & engine will stall
Won't start , will run un starting fluid
I wan't to eliminate the engine zone control cable.I will be elimating the battery and key start.are there any wires that need to be diconected,etc.?
assembly[key start]and replace the throttle cable cable with genaric throttle cable.the cable that is on the craftsman lawn mower[model # 917.377574]with a genaric cable.Are there any wires that need to be modified?
