Question about Microwave Ovens
GE PEB 1590 The turntable and fan (NOT the magnetron) run when I open the door. I think the door interlock is sticking, if I probe the lower interlock I can get it to stop, but the next time I close and open the door the turntable and fan start up again. Otherwise, it works as normal when the door is closed.
    Sergeant:
  • Microwave Ovens Expert
  • 256 Answers
Replace defective microswitch.
Posted on Nov 28, 2017
3 Suggested Answers
SOURCE:
SOURCE: Door shut off malfunction
I have the same problem starting yesterday April 19. Have you gotten any answers.
Posted on Apr 20, 2008
dondaine
I have a similar problem. The only answer I got said I might have a falty switch, to witch I replied the the problem was logic and not necessarely mechanic. If you get deeper insight let me know please!
Posted on Nov 18, 2015
Tip
Troubleshooting Guide
  • Problem: Totally dead oven.
    Possible causes:
    1. No power to outlet (blown fuse or tripped breaker or GFCI).
    2. Blown main fuse - likely due to other problems.
    3. Open thermal protector or thermal fuse.
    4. Defective controller or its power supply.
    5. Clock needs to be set before other functions will operate (some models).
  • Problem: Totally dead oven after repair.
    Possible causes:
    1. Cabinet screws replaced in incorrect location (safety interlock not engaged).
    2. Any number of screwups. :)
  • Problem: No response to any buttons on touchpad.
    Possible causes:
    1. Door is not closed (some models).
    2. You waited to long (open and close door to wake it up).
    3. Controller is confused (pull plug for a minute or two to reset).
    4. Defective interlock switches.
    5. Faulty controller or its power supply.
    6. Touchpad or controller board contaminated by overenthusiastic cleaning.
    7. Defective/damaged touchpad.
  • Problem: Oven runs when door is still open.
    Possible causes:
    1. Damaged interlock assembly.
    2. Cooling fans (only) running due to bad sensor or still warm.
  • Problem: Oven starts on its own as soon as door is closed.
    Possible causes:
    1. Defective triac or relay.
    2. Controller is confused (pull plug for a minute or two to reset).
    3. Defective controller or its power supply.
    4. Touchpad or controller board contaminated by overenthusiastic cleaning.
    5. Defective/damaged touchpad.
  • Problem: Oven works but display is blank.
    Possible causes:
    1. Defective controller or its power supply.
    2. Broken display panel.
    3. Oven needs to be reset (pull plug for a minute or two to reset).
  • Problem: Whacked out controller or incorrect operation.
    Possible causes:
    1. Previous or multipart cook cycle not complete.
    6. Defective sensor (particulalry covection/mirowave combos).
  • Problem: Erratic behavior.
    Possible causes:
    2. Bad connections in controller or microwave generator.
    3. Faulty relay - primary (or HV side, much less commonly used).
    5. Bad contacts/connections on mechanical timers. Intermittent fuse.
    6. Power surge at start of cook cycle confusing controller.
    7. Microwave (RF) leakage into electronics bay.
  • Problem: Some keys on the touchpad do not function or perform the wrong action.
    Possible causes:
    1. Touchpad or controller board contaminated by overenthusiastic cleaning.
    2. Defective/damaged touchpad.
    4. Faulty controller.
  • Problem: Microwave oven does not respond to START button.
    Possible causes:
    1. Defective START button.
    2. Faulty interlock switches.
    3. Door is not securely closed.
    5. You waited too long - open and close door to wake it up!
  • Problem: No heat but otherwise normal operation.
    Possible causes:
    1. Blown fuse in HV transformer primary circuit or HV fuse (if used).
    2. Bad connections (particularly to magnetron filament).
    4. Open HV capacitor, HV diode, HV transformer, or magnetron filament.
    5. Shorted HV diode, HV capacitor (will blow a fuse), or magnetron.
    6. Defective HV relay (not commonly used).
  • Problem: Timer and light work but no heat, cooling fan, or turntable rotation.
    Possible causes:
    1. Defective (lower) door interlock switch or door not closing fully.
    2. Faulty relay or triac.
  • Problem: Fuse blows when closing or opening door:
    Possible causes:
    1. Defective door interlock switch(s).
    2. Interlock switch knocked out of position.
    3. Misaligned door.
  • Problem: Loud hum and/or burning smell when attempting to cook.
    Possible causes:
    1. Shorted HV diode, magnetron.
    2. Burnt carbonized food in or above oven chamber.
    3. Shorted winding in HV transformer.
    4. Frayed insulation on HV wiring.
  • Problem: Arcing in or above oven chamber.
    Possible causes:
    1. Burnt carbonized food deposits.
    2. Exposed sharp metal edges.
  • Problem: Fuse blows when initiating cook cycle.
    Possible causes:
    1. Defective interlock switches or misaligned door.
    2. Shorted HV capacitor.
    3. Shorted HV diode.
    4. Shorted magnetron (probably won't blow main fuse but HV fuse if used).
    5. Defective triac.
    6. Old age or power surges.
    7. Defective HV transformer.
    8. Short in wiring due to vibration or poor manufacturing.
  • Problem: Fuse blows when microwave shuts off (during or at end of cook cycle).
    Possible causes:
    1. Defective triac (doesn't turn off properly).
    2. Defective relay.
    3. Shorting wires.
  • Problem: Oven heats on high setting regardless of power setting.
    Possible causes:
    1. Faulty primary relay or triac or HV relay (not commonly used).
    2. Faulty controller.
  • Problem: Oven immediately starts to cook when door is closed.
    Possible causes:
    1. Shorted relay or triac.
  • Problem: Oven heats but power seems low or erratic.
    Possible causes:
    1. Low line voltage.
    2. Magnetron with low emission.
    3. Faulty controller or set for wrong mode.
    4. Stirrer (or turntable) not working.
    5. Intermittent connections to magnetron filament or elsewhere.
    6. Faulty primary relay or triac or HV relay (not commonly used).
  • Problem: Oven heats but shuts off randomly.
    Possible causes:
    1. Overheating due to blocked air vents or inoperative cooling fan.
    2. Overheating due to bad magnetron.
    3. Bad connections in controller or microwave generator.
    4. Faulty interlock switch or marginal door alignment.
    5. Faulty controller.
    6. Overheating due to extremely high line voltage.
    7. Stuck stirrer fan resulting hot spots detected by sensors.
  • Problem: Oven makes (possibly erratic) buzzing noise when heating.
    Possible causes:
    1. Fan blades hitting support or shroud.
    2. Vibrating sheet metal.
    3. Vibrating transformer laminations.
    4. Turntable or stirrer hitting some debris.
  • Problem: Oven light does not work.
    Possible causes:
    1. Burnt out bulb :-).
    2. Bad connections.
  • Problem: Fans or turntables that do not work.
    Possible causes:
    1. Gummed up lubrication or bad motor bearing(s).
    2. Loose or broken belt.
    3. Bad motor.
    4. Bad thermostat.
    5. Bad connections.
on Mar 30, 2008 | Kenmore 80412 Microwave Oven
GE Spacemaker XL1800 not working?
  • Open internal fuse
  • Magnetron failure
  • Faulty door interlock
  • Faulty control board
Feb 05, 2018 | GE Microwave Ovens
Microwave light stays on and unit won't heat/run
If it's not heating at all, the magnetron is to blame.
May 26, 2012 | GE JVM1330BW/WW Microwave Oven
The fan runs when the door is open just like it does when it's running. When the door is shut and not running the fan is off. I opend/shut the door 3 times firmly like the GE rep. told me to but it still...
Hi.
Disconnect the oven from power and allow cooling down. Most GE have temperature controlled fan system.
The Fan is controlled by main pcb and powered along the line passing through the door lock switch, with circuit supplying power to the magnetron and turntable motor.
The fan is also operated directly by the control board.
If the turntable was also running, then the door switch is shorted. In that case the magnetron may be working as well, better not to start the microwave oven.
If only the fan is running, then the main pcb must be replaced, or the damper motor relay must be replaced.
Call GE and arrange repair, the unit is faulty.
Apr 26, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Are there any recalls on GE microwave JVM1540DN1ww Thanks, ssi96@aol.com
There are no recalls on GE over the range microwave JVM1540DN1WW but there SHOULD BE! Mine lasted only a year and a half and then started running and heating with the door open. Shortly after that it stopped heating at all. The light and fan works, and the keyboard lights up but the turntable doesn't turn anymore (yes I made sure the turntable was turned on), and it doesn't heat. It will count down like it's heating but it doesn't heat. Changing the door switches didn't work. Husband thinks it is the magnetron which is expensive to fix. I won't ever buy another GE microwave period! Check the web and you will see all the similar complaints. I just searched online and for a lesser price than I paid for the GE, Samsung sells one that has the one year warranty but also has a 10 year warranty on the magnetron.
Jan 25, 2010 | GE Microwave Ovens
I have a 1993 GE spacemaker microwave/range hood combo. Everything works except that for most of the day it did not heat the food. The turntable still worked and the oven still appeared to be running. Then...
In short yes it can happen again.
Intermittent operation can be caused by a door interlock micro switch, a weak capacitor, an intermittent wiring connection from heat or poor connection, a marginally performing diode or a sticking Magnetron. Except for the Magnetron all other repairs would be worth the expense.
Repair costs and parts for most everything else will be between $65 and $100.00 depending on the part(s) replaced. Replacing the Magnetron would cost more than 50 % of the total unit replacement cost.
Jan 17, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Dacor dcm24s.light, fan, and control panel work but turntable and heat do not
Most likely the bottom door switch. Dacor units are built by Sharp and that switch is a very common problem. You'd either need to check the switch with an ohm meter or remove the cover of the switch to see if it's burned inside.
Oct 20, 2008 | Sharp R-930AK Convection/Microwave Oven
Mar 12, 2008 | Panasonic NN-T993SF Microwave Oven
Microwave Ovens Logo
55 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
