Proform Crosswalk 500 Treadmill Logo
Anonymous Posted on Jun 07, 2009
Motor runs for a second or two on proform 550e, then stops
My problem was exactly as stated by the previous person. It started after a ball lodged under the walking area. I turn it on, the motor runs like a charm for a sec or two and then stops.
Anonymous
Level 2:
New Friend:
  • Expert 64 Answers
  • Posted on Jun 08, 2009
Anonymous
Expert
Level 2:
New Friend:
Answers
64
Questions
0
Helped
57400
Points
141
Speed sensor.
Testimonial: "Thank you, my daughter has ordered one."
tel66421938
Level 1:
Habit-Forming:
New Friend:
  • Contributor 26 Answers
  • Posted on Oct 18, 2016
tel66421938
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
26
Questions
0
Helped
16660
Points
53
AT FIRST YOU CHECK SPEED SENSOR IN FRONT OF ROLLER BELT OF TREADMILL OR SOMETIMES IT IS MOUNT ON MOTOR THIS PART HAVE 2 OR 3 WIRE THAT FOLLOW TO CONTROLLER MOTOR BOARD .
I have a proform 550e, starts up fine runs well for a few minutes, then belt stops. Motor keeps running. I step off the belt, belt starts to run again.
check adjust belt tension
may have to clean under belt area as there could be a build up that is stopping the free movement of the belt as it gets hot
How do I determine if the drive motor on Proform Crosswalk 397 needs replacement.
Unplug the motor from the board and plug it in to an 18 volt drill battery to see if it runs. It more than likely will and this means the motor control board is bad. You can get lucky on ebay occasionally and get one in the 50-60 dollar price range but don't go any higher then that amount. These boards are built to fail and to replace them new costs more then the treadmill is worth. Mine had a blown capacitor only and I replaced it with exact same and still no luck. Junked it and wont replace unless I buy it used and dirt cheap. Good luck.
Proform C950 intermittently stops working shortly after start
please see the video attached. lube the rollers bearing front+ back
2) test the input terminal voltage motor, if there ARE the motor is faulty. see my personal TIPS for motor help 3) test the output voltage board, if there ARE NOT voltage for input voltage MOTOR, the board is faulty.
God bless you
Treadmill proform model 831.29605.0 (proform xp 550e was working fine till I Changed the walk belt. After changing belt, display looked ok but treadmiil would non trurn on. Operated incline. incline
1) i recommend that you lube very well deck belt + rollers bearing
2) see the videos.
3) see the block
4) Try to RUN the software calibration, for troubleshooting.
5) measure the input voltage motor, if there are the motor need repair.
6) Measure the output voltage board, for input voltage board, if there are NOT, the board is faulty.
Treadmill Proform 450CX: unstable speed - no motor strengh
1) You must RUN the software calibration for diagnose, and troubleshooting, and fix it Inmediately.
God bless you
When I turned ON my proform 550e the speed is super high making imposible to even try to run on it, after pressing the speed down arrow the motor stops completely. I do not have any control on the speed,...
adjust the speed sensor, clean, and tigh the connector very well, see the diagram attached,
2) RUN the software calibration for diagnose, and troubleshooting and fix it.
sincerely .God bless you
I have a proform xp 550e trademill and i changed the motor control board because the motor start running and inmediadlly stops. after i installed the board the motor start running and stop some time after...
To calibrate the speed follow these steps.
Press stop and speed up and place the safety key in its spot.
release the stop and speed up.
Press stop again. The windows on the console (speed & time) will be all zeros.
Press speed up, the time window will increase. The belt should start to move. Increase this number to 85. This is maximum speed. Adjust the potentiometer to the correct maximum speed. The console will beep until the correct speed is adjusted (+ or - .2mph).
If the machine suddenly goes dead when in use, you may have a static electricity problem.
Check that the ground pin is present on the plug and check your outlet for a proper ground connection.
Not really a problem just would like to see an owners manual for the proform 550E treadmill.....
go to:
http://www.iconservice.com/manuals.html
fill out form......search.... view manual in PDF Format
Print
Top Proform Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
john h
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
