Question about Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966
Cannot disassemble Troy-bilt trimmer head
I need to replace Troy-bilt trimmer head. However, I couldn't figure out how to remove the outer cup of the trimmer head. Any help would be greatly appreciated. Thanks!
There is a round, rotary black part between the metal piece to which the cutting head attaches and the outer plastic seat of the cutting head. There are two square slots, each about a quarter inch wide, on opposites sides of the black piece. Slide an Allen wrench or something similar firmly into the slot. Holding the Allen wrench in a stable position, turn the outer plastic ring of the cutting head (it has scalloped edges that can be gripped firmly) counter clockwise to unscrew the cutting head from the bolt on which it is mounted. Be careful with the tool (e.g. Allen wrench) used to hold the black piece steady, as it is plastic and could be damaged by the edge of the tool.
Posted on May 04, 2011
  • 2 more comments
  • Jason Rizos Jul 06, 2011
    Holy cow this saved my neck. I could not for the life of me figure out where the "break" was between the head and the shaft. Thanks so much.
  • debbie ratliff Sep 04, 2011
    You are a lifesaver. I was on the verge of insanity until I read your solution. I could not figure out how that thing came off. Thank you! Thank you!! Thank you!!!
  • douglas Ragland Jun 12, 2013
    Forget everything that was said above, let me tell you it can be replace. Cut away all the plastic Bump Head Assembly and you will see the nut on the shalt.. If you want to replaced with genuine parts check out this web sitehttp://www.mtdparts.com/
  • Tate Antici
    Tate Antici Jun 18, 2017
    The bolt that goes into the shaft is stripped and I can't remove it. Any ideas?
    New Friend:
I bolt going into the shaft is stripped and I can't remove the head. Any ideas?
Posted on Jun 18, 2017
  • Anonymous Jun 25, 2017
    Pull the black plastic knob (bump head cover) off with the end of a hammer or a large screwdriver. That'll expose the bolt. Then hit the bolt head-on with a hammer. That worked for me. The bolt loosened and I could take it off with my hands. I think the bolt gets jammed sometimes.
  • Early May
    Early May Jun 25, 2017
  • 1,041 Answers
There should be a rounded cap at the bottom of the spool where the string is. Just unscrew it counter clockwise. It should come right off.
Jim
Posted on Jun 07, 2009
  • Jim Parker
    Jim Parker Jun 12, 2009
    Thanks for the rating.
    If you should have any questions about "Drywall Finishing/Patching", or know someone who does, put your questions to Category: "Tools- Building & Power- HAND TOOLS" at FixYa.com
    Jim
SOURCE:
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/.../troybilt/TB22EC-trimmer
Troy?Bilt Products
Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
www.troybilt.com/.../troybilt/tb35-ec-curve-shaft-gas-...
Troy?Bilt Products
Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
Dec 09, 2015 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Replacing starter recoil rope on troy bilt 4-cycle cultivator
Either contact the company or Google the model number for a service manual.
Jun 14, 2012 | Garden
I have a TB525EC trimmer with the "new" string
Great question! You can always go to the Home Depot and purchase a "universal-type" retro head and if it doesn't fit correctly, just return it for a refund or go on a site like Ebay and buy a genuine Troy Bilt retro type string head. I bet they will fit.
Nov 12, 2010 | Troy Garden
The flexible drive shaft broke near the bottom. I have removed it from the motor end and pulled out whats left of the shaft, but cannot figure out how to get to the broken end so that the flex shaft can be...
I believe what you need to do is remove the 3 screws on the trimmer head to remove the head from the lower shaft. After the head is off you can look down into where the shaft goes and be able to use some needlenose pliers or something of the sort to pull the broken part out.<!-- from fixya rte -->
Jul 06, 2010 | Troy Bilt Tb70ss Gas Trimmer
My troy bilt tb70ss trimmer sounds like something is stripped the motor will wind out but the head wont move its only 1 1/2 years old
will need to check if any debris is wrapped around head jamming the head --or -flex shaft is jammed or damaged separate shaft from motor and will see in shaft the flex shaft that turns the head try turning head by hand and observe flex shaft if binding or broke need to lube or replace
Jun 28, 2010 | Troy Bilt Tb70ss Gas Trimmer
How do you disasemble the head on the 4 cycle gas troy bilt trimmer
the head is bolted down by 4 torque bit screws some people call them star wrenches from the top but all plastic & carb needs to be removed more less everything to get to the bolts around the cylinder head as well as crankcase but to be honest its cheaper to buy a new one then repair it i had one repaired it & by the time i replaced everything i could have bought a new one cheaper then the parts cost me
Jul 09, 2009 | Troy Bilt Tb70ss Gas Trimmer
How to replace air filter on Troy-bilt TB20CS?
May be air filter but sounds more like your muffler is stopped up. First take the muffler off and see if it runs better without it. If so, burn the carbon out of the muffler and clean the muffler port on the engine. If not, then remove the four screw at the very end and disassemble. The ait filter is in that area. Diagram is located at
www.stollerlawnandgarden.com/.
Click on parts lookup in left hand column.
Jun 24, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Line stuck inside head of troy-bilt trimmer
Take an awl or small diameter screw driver, same size or a bit smaller dia. than the line dia., and push it through the hole from the outside of the line head. This should push the piece of old line through the hole.
Recommendation: Leave at least one inch of line on the inside of the head, so you can grab it easily when you have to replace the line. I'll carry a pair of long nose pliers on me when I use my trimmer, so I can easily grab hold of the inside piece to pull it through.
Jun 12, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Can not remove troy bilt weedeater head
Once all the bolts are removed, tap all the way around, (with a rubber mallet), where the head meets the bottom portion of the motor. It should come right off with a little coaxing.
Jim
Jun 08, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Homelight MightyLite 17" Straight Shaft Trimmer
a lot of times there is a hole in the side of the head to insert a rod into so the head doesnt spin..now all you have to do is figure whitch way it turns as some a left hand thread
Aug 06, 2008 | Troy Bilt 17 Inch 29 Cc Gas Powered...
Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966 Logo
17,196 people viewed this question
Top Troy Garden Experts
Neil Hancock
Jay Finke
Jay Finke
lnbn1975
Are you a Troy Garden Expert? Answer questions, earn points and help others
