Nordic Track NordicTrack Elite zi Treadmill Logo
A
Anonymous Posted on Feb 08, 2014
Disassemble my Nortic Trak Elite ZI - Nordic Track NordicTrack Elite zi Treadmill
1 Related Answer
mvogt55239
Sportsmith LLC
  • 920 Answers
  • Posted on Jan 04, 2016
SOURCE: disassembling my 1500 nortic track treadmill
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
The following link is to a manual for your model. This should provide some insight before disassembling the unit. The most important part is to label the connection wires so that you are sure where they go when you put it back together. Also be considerate of any pinch points so that you do not accidentally pinch or crimp any wires when putting it back together.
249920 NORDICTRACK 1500 TREADMILL SPORTSMITH net
Nordictrack elite zi beeps,not working
please keep from standing on your machine once you turn it on and test the buttons to notice if you experience anymore beeping. If not, then the area below the belt might need some oil to lower friction. If so, please check that all covers for any power source or circuitry are put into place properly. Otherwise, you might need to have the
Thank you.
Disassembling my 1500 nortic track treadmill
My elite zi will power on but only beeps??
1) you must adjust the REED switch, clean it and tight the wires connector very well.See the diagram
2) when you fix it, RUN the software calibration for diagnose, troubleshooting and fix it.
God bless you
How do I disassemble the Nordic Track t5 zi for transporting?
Please read you owner manual.
If you do not have please go to www.nordicktrack. com then customer service and then parts & manual, give you model, etc, and download free and read the section how to fold and viceversa.
sincerely
2answers
I lost the safety key how can i replace it?
You can buy a replacement key from ICON Health and Fitness online or by telephone
Part # 264413
@ http://www.iconservice.com/CustomerService/parts.do or call 1-877-993-7999
hope this helps
3helpful
Lost my manual. having tracking problems with the belt on my machine. how do i adjust the tracking? thank you,
You can download the manual in PDF Adobie Acrobat form here
http://www.iconservice.com/CustomerService/manualsProductManuals.do?model=24811&modelName=NORDICTRACK+ELITE+ZI+TREADMILL&version=0&company=11&language=
I have a NordicTrack Elite zi treadmill. While running I hear a ratcheting click coming from the front housing area. When I hear this ratcheting click the belt is slipping a little bit. Any ideas of...
This is more than likely a loose drive belt, which would explain the slipping as well as the sound. To tighten this take off the plastic cover that covers the motor. You will see where the motor connects to the front roller with the drive belt. To tighten it there are two bolts that hold the motor to the machine, loosen those then pull it tight and retighten them, This should eliminate the problem.
My Nordic Track EXP 1000 won't run.
Has the safety key been inserted? It sound like that what is missing for it to work if that the case call Iconfitness @ 1-800-999-3756.
Part #: 264413
Part Name: ASSY,CLIP,ROPE/KEY
Model: 248110 - NORDICTRACK ELITE ZI TREADMILL
Part List: #264413 - KEY/CLIP
Quantity on Model: 1
Price: $9.82
Top Nordic Track Exercise & Fitness Experts
ZJ Limited
ZJ Limited
vince
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
