SOURCE: jazz dv179
Now, I get it. At the "back bottom" of the camera is the USB slot which is used to connect the camera to the computer (for downloading) via the cable supplied with the camera. It is ALSO the 'female" for connecting with the "male" end of the power cable.
For 'Kimmys', guess you meant camera, not computer, in your message. And yes, the light indicates it is charging.
SOURCE: Jazz DV179
What are you talking about " Through the power plug" and not the USB, there is only a USB for you to plug into. Check your FACTS before posting replies to serious questions please
SOURCE: JAzz DV179
Well.. I have to plug in the charger that came with the dv-179. If I use my Phone (motorola usb) charger, or a USB cable (into the computer or a hub), all it does is light up the back red light (and not the front 'self timer' led) and does not charge the camera. So remember, if the back led lights up, you've got the wrong charger!
SOURCE: Jazz DV 179 Camcorder
I believe that the camera will not charge directly from the computer - testing this theory myself... however I went to Radio Shack tonight and they have them there for 30 bucks (a bit outragious if you as me)
SOURCE: Jazz DV-179
YOU PEOPLE IT IS JUST THE BATTERY THAT IS IN IT!.. BECAUSE THAT BATTERY IS NOT ONLY FOR AFTER IT IS CHARGED IT ALSO WORKS TO SHOW THE DISPLAY SCREEN! BECAUSE IF YOU TAKE OUT THE BATTERY THE LIGHT STAYS ON WHILE ITS PLUGGED INTO THE COMPUTER! MY BF IS HAVING THE SAME PROBLEM TRY BUYING A NEW BATTERY!! ITS THE SOLUTION! the battery is caput!
