The pilot light turns on but wont stay lit.
Troubleshoot following link:
http://waterheatertimer.org/troubleshoot-water-heater-pilot-light.html
SOURCE: reliance gas water heater 640ycrs pilot light will
if water heater will heat a tank of water before the pilot light goes out you need to replce the gas thermostat
SOURCE: Pilot won't stay lit in Reliance 606 gas water heater
The Reliance 606 has an enclosed thermal couple. Before you try taking that assembly apart take a wire brush to the bottom opening directly under the burner. There is a metal filter on the very bottom of the water heater. It could be that the filter has gotten filled with dust or animal hair. It took a serviceman 2 days to figure this out for me. The water heater has to have good airflow through that filter to work well.
SOURCE: I have a reliance 805pv
OK, make sure your ON-Pilot-OFF knob is turned to "ON" after you light the pilot. Then make sure the temperature dial is not set at vacation setting. It should be set to atleast mid range between low and high at the "A" or triangle symbol, depending on what dial you have. It will take 20-30 minutes for the water to get hot, but the burner should come on right away after it has been relit. If not, you may have to call your local gas co to look at it. Douglas
SOURCE: I have a Reliance water heater - 40 gal Model
In my first 15 years as a plumber I never saw a pilot light issue on a gas WH that a new thermocouple didn't fix. Since the government mandated a redesign of the fire box, I've seen three that nothing ever fixed - two Whirlpools and one (my usually ultrareliable) AO Smith - including replacing the entire burner assembly and the regulator. And I've heard of many others.
Check the thermocouple connection for tight. (Don't strip.. threaded soft metals.)
Check the microvents on the bottom ? of the burn box for dust, even if it is new.
Call Reliant and demand new units until you get one that works.
Try another model. Consider a 52gal electric.
I've always recommended gas over electric, and AO Smith and Rheem were my recommendations (and "Reliants" were "lumber yard" water heaters. Sorry.)
Since the mandated redesigns, I don't really have a "proven reliable" model to suggest. I increasingly believe the restricted air flow design is the ultimate culprit, including any changes to the thermocouple/regulator construct to accommodate the restricted air flow design. Just my hunch.
Offered for what its worth. -- plumber in Indiana.
SOURCE: i light the piuolot button
When you light the pilot lite you have to hold the button down until it gets the element hot enough to stay lit. If you hold down the button and lite the pilot and let it go right away it will go out. What to do is hold down the button and lite the pilot and continue to hold the buttn down for about 45 seconds to a minute then let it up very slowly and you will see if it is going to go out by the flame getting smaller as you let up on the button. If it does start to get smaller conitnue to hold it again for a few seconds and repeat the process of letting it up slowly. when the control element gets to the right temperature it will stay lit then turn your valve to "ON" and the fire will start up and continue to heat the water.
