There are many possibles that can cause "Close Front Cover"
Check the front cover actuator, switch. If all covers, switches is working fine, probably power supply is faulty.
Toshiba e-STUDIO 2330c Is given error message "Close Front Cover". The front cover is closed and I can not get error message to go away.
Where can I buy Power Supply (6LG03347000)
A firmware update for the Lexmark
Prospect Pro205 will help fix the printhead issue you are experiencing. Please
follow the steps below on how to successfully update your printer:
Open
the printer cover and remove the printhead and tanks (if installed). Note:
Carrier will come to the center automatically with this error message as
the cover is opened. Remove the ink tanks > open the printhead latch
and remove the printhead > close the printhead latch, close the printer
cover and confirm the error message goes away from the operator panel.
After successfully updating
your printer, open the printer cover > re-insert the printhead > close
the printer cover. If no printhead error comes up, continue with normal
installation steps for cartridges. If error comes up again, please contact
Lexmark Technical Support Center for further assistance.
there is a switch at the side that is being push by the cover when it closes check this switch to be sure it hits the button when close or you may replace the switch it has a problem.
there may be any struck between the cover open switch which is in main board of the printer and the lever in the cover. open the cover and press the lever behind the cover. if the cover open message go away then do the same for 2 - 3 times after close the cover and try. even now he same problem happen make some arrangement or stick a paper bit on the top of the lever so as to enable it to press the sensor properly
There is a little black lever in the middle that needs to be re inserted properly. (like a little black stick in the middle. Needs to slide to the left or right. See more of this one the site. It solved it for me.
If you open the back cover (depress the release button on the top right) If you lift it up look for two black anchors that grab the base when you close the lid. I have one that has a broken tab on the left side, which happens to be the same side as the cover closed switch. If the top is not closed all the way the rollers do not line up and the cover switch is not depressed to let normal operation. Also, if the switch arm is busted (case colored plastic push pin protruding from the cover) it will not make contact with the switch when closed. Try closing the cover and push down on left side of the fax. Does the error go away? If not, the actuator arm or the switch are bad.
The cover may not be prperly closed. Is it difficult to close? Sometimes the cartridge may not be inserted correctly so that the cover won't close properly.
