Question about Saeco Stratos Coffee Maker, Espresso Machine
Ventilate problem No matter what i do, the Ventilate message wount go out
SOURCE:
  • 6 Answers
SOURCE: my coffee machine says "ventilate"
When it says to ventilate, it is asking you to prime the pump. Put acup under the panarello wand ( the steamer/frother) to catch thedischarged water and press the hot water button (upper left button onmy machine). Wait until air stops coming out with the water, usually3-5 ounces, and then press the hot water button again.
You machine is now ventilated (primed) and should be ready to go.
Posted on Jan 24, 2009
EsWorld
  • 1618 Answers
SOURCE: New Royal espresso machine
Run hot water cycle to ventilate machine.
Posted on Mar 09, 2009
PlatoAu
  • 67 Answers
SOURCE: display says "ventilate" and won't operate
run hot water from the steam nozzel (for few seconds) to purge the air out of the system
you propabably ran out of water making your previous coffee?
Posted on Apr 10, 2009
  • 1089 Answers
SOURCE: ventilate message, but no air in system
HI Sorry, but that sounds like a bad flow meter. The flow meter is not that hard to replace, with a little common sense, but the new flow meter should be the brass one. There are some tricks to getting the top back on, Pull forward on the bypass doser chute a little so it will center in the opening. You don't have to disconnect all the wires that go to the top. They are long enough that the top will set behind the machine carefully. Remember the tubes that go to the flow meter. You don't want to get them backwards.
Posted on Jun 14, 2009
EsWorld
  • 1618 Answers
SOURCE: What do you do about the ventilate message
Ventilate is the same as priming the machine open the hot water valve to purge the hydrallic system.
Posted on Jan 24, 2010
We are getting a "ventilate"
Hi.
When you get ventilate the machine functions are locked. Try following the indications here:The following procedure works when you get the ventilate error: The Ventilate sign can...
Regards.
Ginko
Mar 03, 2011 | Gaggia Titanium Espresso Machine
Machine wont make coffeee, m,essage says ventilate...
You need to push the hot water button on the machines panel to allow water to run out of the steam wand. After a few seconds the machines ventilate message should clear.
May 20, 2010 | Saeco Stratos Coffee Maker, Espresso...
Keep getting ventilate message - won't ventilate and cannot operate steam or grinder w/ ventilate message
Try this run the hot water cycle for a few seconds, it that works, try steaming if you get the message again clear it by running the hot water cycle and then go to steaming, this time push in on the knob after you open it, it that works, then the tap rod or the valve assembly needs to be replaced.
May 01, 2010 | Gaggia Titanium Espresso Machine
Ventilate message
Press the hot water button and allow water to flow from the steam arm until ventilate disappears and warming up appears on the display.
Ventilate after descale is normal.
Feb 22, 2010 | Gaggia Titanium Espresso Machine
I have saeco incanto deluxe coffee machine,ventilate msg appears
Check the end of the steam nozzle, make sure it is not blocked. If not then with the knob open for hot water cycle push in on the knob if that works then the tap rod assemble or the steam valve needs to be replaced.
Feb 20, 2010 | Saeco INCANTO DELUXE Espresso Machine
Jan 24, 2010 | Saeco Magic Comfort Plus Espresso Machine
How to ventilate a saeco cafe royalecoffee machine
Hi
There is a water button you need to push. It has a water drop on it. This will clear the ventilate message.
Jan 22, 2010 | Saeco Royal Professional Espresso Machine
Can't get rid of ventilate message on titanium plus machine
Try this, after opening hot water valve, push the knob in when it asks for ventilate. If that works then contact your nearest gaggia distrubutor and ask for a new stainless steel steam valve assembly.
Jul 04, 2009 | Gaggia Titanium Espresso Machine
Ventilate!
Can you get water out of the machine by pushing the hot water button?
This is how you would remove the ventilate message in the first place, but if no water comes out then the machines electro-valve is not opening and you will not be able to remove the ventilate message. You will have to get the machine serviced.
I would also give descaling the machine a try before servicing the machine.
You can also find the user manual for the royal professional on our website: http://www.cerinicoffee.com/Saeco_User_manuals_free.asp
We are a Authorized Saeco Service Center based out of New York.
For Saeco Parts and Cleaning supplies visit www.CeriniCoffee.com
May 29, 2008 | Saeco Royal Professional Espresso Machine
Saeco Magic comfort
turn the hot water / steam knob on to 'ventilate' the pressure from the machine. The ventilate /overtemperature message will disappear when ready (few seconds usually)
Oct 26, 2007 | Saeco Magic De Luxe Espresso Machine
Saeco Stratos Coffee Maker, Espresso Machine Logo
32 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Pierre Laplante
Ray Murphy
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
