Konica Minolta bizhub 250 All-In-One Laser Printer Logo
Posted on Oct 26, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bizhub C252 -- printer defaults not retaining account tracking passwords
We use the Bizhub on a Windows XP network with multiple users where each user can log on as himself at any computer using a roaming profile.  I want to set the Bizhub printer defaults for each user so that their user name and password are preset under Account Tracking.  It works fine when I set the default values for one user, but when I set the default values for a 2nd user, it erases the values for the 1st one.
  • Anonymous May 24, 2009
    how do I print poster mode on c451
Anonymous
Level 2:
  • Expert 167 Answers
  • Posted on Jan 08, 2008
Anonymous
Expert
Level 2:
Answers
167
Questions
Helped
198013
Points
292
When you create account codes they are assigned a number, are you sure you are not starting at the end? It should only erase the previous information if you turn account track on then off.
[email protected]
How to install konika minolta with computer
To get to the network settings: Press the Utility/Counter key, select Administrator Settings, enter 12345678 as the password, then select network settings. You will find all the settings for networking the machine there. The print drivers can be downloaded from Konica's web site: kmbs.konicaminolta.us
User manuals can be found there as well.
tip
Three Tips for Windows XP Administrator Password Recovery
Unlike Windows 7 and Vista, the default administrator account on Windows XP is enabled and not password protected. And by this unique feature, you can easily reset a forgotten login password to Windows XP when you are locked out of computer. But if you added a password to this built-in administrator account before and now cannot remember its password, what will you do to reset this forgotten Windows XP default administrator password? Here's some advice on <a href="http://www.anypasswordrecovery.com/windows-xp-administrator-password-recovery.html">Windows XP administrator password</a> recovery for you if your Windows XP machine is in use.<br /><br />Tip 1: Take advantage of password recovery disk<br /><br />Provided a password reset disk for the default administrator account is created in advance, Windows XP administrator password recovery can be completed within a few clicks.<br /><br /><img src="yaoch_1.png" /><br /><br />Step 1. Go to Windows XP logon screen and enter a wrong password for the administrator account.<br /><br />Step 2. Press Enter to pop up the "logon failed" dialog box, and click "use your password reset disk".<br /><br />Step 3. On the Password Reset Wizard screen, click Next to change this administrator password.<br /><br />Tip 2: Try Windows Password Recovery Software<br /><br />If you forgot Windows administrator password without a password reset disk, don't feel impressed. <a href="http://www.anypasswordrecovery.com/" style="font-weight: bold;">Rekeysoft Windows Password Recovery</a> can solve your problem. It allows you to create a password reset CD/DVD to reset lost Windows XP administrator password.<br /><br /><img src="yaoch_2.png" /><br /><br />Step 1. Download and install Windows Password Recovery.<br /><br />Step 2. Burn a bootable password reset CD/DVD.<br /><br />Step 3. Boot your locked computer form the CD/DVD.<br /><br />Step 4. <a href="http://www.anypasswordrecovery.com/reset-windows-xp-password.html">Reset Windows XP password</a> under Win PE.<br /><br />Step 5. Log on computer via this administrator account without password.<br /><br />Note: With intuitive GUI, you can defeat Windows XP administrator password within a few clicks, regardless of your level of computer knowledge. 100% recovery rate guaranteed.<br /><br />Tip 3: Use a user account with administrator permission<br /><br />It is well-known that users can create 2 kinds of administrator account on Window XP. One is a user account with administrator privileges while the other is the built-in administrator account. So when you forgot Windows XP default administrator password, you can log on computer with another kind of administrator account and then do as follows:<br /><br /><img src="yaoch_3.png" /><br /><br />Step 1. Right-click My Computer icon to select Mange.<br /><br />Step 2. On the coming up classic computer management window, expand Local Users and Groups folder, and then expand Users folder to display all user accounts on this computer.<br /><br />Step 3. Right-click Administrator and select Set Password option.<br /><br />Among these tips, it's highly suggested you try tip 2 that changing Windows XP password with Windows password recovery software as it is can be applied to every lost Windows password circumstances. And it is simple and fast.
on Apr 22, 2011 • Computers & Internet
tip
Understanding windows account lockups
Common Causes for Account Lockouts
This section describes some of the common causes for account lockouts The common troubleshooting steps and resolutions for account lockouts are also described in this section.
To avoid false lockouts, check each computer on which a lockout occurred for the following behaviors:
* Programs: Many programs cache credentials or keep active threads that retain the credentials after a user changes their password.
* Service accounts: Service account passwords are cached by the service control manager on member computers that use the account as well as domain controllers. If you reset the password for a service account and you do not reset the password in the service control manager, account lockouts for the service account occur. This is because the computers that use this account typically retry logon authentication by using the previous password. To determine whether this is occurring, look for a pattern in the Netlogon log files and in the event log files on member computers. You can then configure the service control manager to use the new password and avoid future account lockouts.
* Bad Password Threshold is set too low: This is one of the most common misconfiguration issues. Many companies set the Bad Password Threshold registry value to a value lower than the default value of 10. If you set this value too low, false lockouts occur when programs automatically retry passwords that are not valid. Microsoft recommends that you leave this value at its default value of 10. For more information, see "Choosing Account Lockout Settings for Your Deployment" in this document.
* User logging on to multiple computers: A user may log onto multiple computers at one time. Programs that are running on those computers may access network resources with the user credentials of that user who is currently logged on. If the user changes their password on one of the computers, programs that are running on the other computers may continue to use the original password. Because those programs authenticate when they request access to network resources, the old password continues to be used and the users account becomes locked out. To ensure that this behavior does not occur, users should log off of all computers, change the password from a single location, and then log off and back on.
noteNote
Computers running Windows XP or a member of the Windows Server 2003 family automatically detect when the users password has changed and prompt the user to lock and unlock the computer to obtain the current password. No logon and logoff is required for users using these computers.
* Stored user names and passwords retain redundant credentials: If any of the saved credentials are the same as the logon credential, you should delete those credentials. The credentials are redundant because Windows tries the logon credentials when explicit credentials are not found. To delete logon credentials, use the Stored User Names and Passwords tool. For more information about Stored User Names and Passwords, see online help in Windows XP and the Windows Server 2003 family.
noteNote
Computers that are running Windows 95, Windows 98, or Windows Millennium Edition do not have a Stored User Names and Passwords file. Instead, you should delete the user's .pwl file. This file is named Username.pwl, where Username is the user's logon name. The file is stored in the Systemroot folder.
* Scheduled tasks: Scheduled processes may be configured to using credentials that have expired.
* Persistent drive mappings: Persistent drives may have been established with credentials that subsequently expired. If the user types explicit credentials when they try to connect to a share, the credential is not persistent unless it is explicitly saved by Stored User Names and Passwords. Every time that the user logs off the network, logs on to the network, or restarts the computer, the authentication attempt fails when Windows attempts to restore the connection because there are no stored credentials. To avoid this behavior, configure net use so that is does not make persistent connections. To do this, at a command prompt, type net use /persistent:no. Alternately, to ensure current credentials are used for persistent drives, disconnect and reconnect the persistent drive.
* Active Directory replication: User properties must replicate between domain controllers to ensure that account lockout information is processed properly. You should verify that proper Active Directory replication is occurring.
* Disconnected Terminal Server sessions: Disconnected Terminal Server sessions may be running a process that accesses network resources with outdated authentication information. A disconnected session can have the same effect as a user with multiple interactive logons and cause account lockout by using the outdated credentials. The only difference between a disconnected session and a user who is logged onto multiple computers is that the source of the lockout comes from a single computer that is running Terminal Services.
* Service accounts: By default, most computer services are configured to start in the security context of the Local System account. However, you can manually configure a service to use a specific user account and password. If you configure a service to start with a specific user account and that accounts password is changed, the service logon property must be updated with the new password or that service may lock out the account.
noteNote
You can use the System Information tool to create a list of services and the accounts that were used to start them. To start the System Information tool, click Start, click Run, type winmsd, and then click OK.
Other Potential Issues
Some additional considerations regarding account lockout are described in the following sections.
Account Lockout for Remote Connections
The account lockout feature that is discussed in this paper is independent of the account lockout feature for remote connections, such as in the Routing and Remote Access service and Microsoft Internet Information Services (IIS). These services and programs may provide their own unrelated account lockout features.
By default, IIS uses a token-caching mechanism that locally caches user account authentication information. If lockouts are limited to users who try to gain access to Exchange mailboxes through Outlook Web Access and IIS, you can resolve the lockout by resetting the IIS token cache. For more information, see "Mailbox Access via OWA Depends on IIS Token Cache" in the Microsoft Knowledge Base.
MSN Messenger and Microsoft Outlook
If a user changes their domain password through Microsoft Outlook and the computer is running MSN Messenger, the client may become locked out.
In this case, since the user has multiple devices connected to the exchange at given time , if he changes the password without disconnecting the other deivices. The account would get locked. You can inform him disconnect all the devices from the exchange except for one machine to change the paswword and then reconnect other devices with new creditentials.
Thanks
Proton
on May 29, 2010 • Computers & Internet
3answers
I kept password for my administrator account..but when iam logging the computer it does not asking password...and directly opening the windows...i wants to keep windows should enter the password on windows...
1) Go to Control Panel on the start menu.
2) Double click on User Accounts.
3) Then under the Pick a Task heading select Change the way users log on or off.
4) Tick the box next to Use the Welcome screen.
5) Then click apply. Password or not when your computer starts up it will take you to the welcome screen where the user can select which account they want to log into.
Account Codes
Yes. Easy to do, just go into the admin mode under utilities. Turn on Copy Track and then setup your accounts. You can restrict color, number of copies etc. This is also in your operators manual.
The default admin password is 12345678
Good Luck
I have a bizhub c250 printer. Is there a way I
YES,
you can use either the User Authentication or Account Track. With authentication you can give public access to BW and require a password for colour. With Account Track you can create users and limt acees, but you CANNOT give public access. ALL users would required to have a code. This is controlled for copy, scan and print functions.
1helpful
Factory settings without the cd rom disk
Default behavior of Windows XP is that it automatically logs in if there is only one user account in the system and is not password protected.
Here is a way to make XP automatically login to a user account.
  • Click Start, Run and type CONTROL USERPASSWORDS2
  • Uncheck Users must enter a username and password to use this computer
  • Click Apply.
  • Now, fill-up your user information and password there.
By default, it shows Administrator. You need to input your username and password.
Delete any account you don't need
Please take time to rate this fixya
110helpful
13answers
Konica Minolta Admin Password
Try 12345678.  That worked for me for my Bizhub C250.
Account tracking set up - now won't print from Windows Explorer / Sage
I had the same problem and realized that the account track password must to be input to the printer that is located in control pannel -> printers and faxes. Not the printer preferences for the application (Word, IE, Excel). Make sure it is set for each user on the system.
3answers
Bizhub 250 scan to email error
Try re-entering user name and password or try a different user name and password for email account saved in the machine.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
