Hone i select start its show on error 3 motor not run plz give me soliton thanks
error 3 means the waking belt starts moving without any command. Make sure that you are not moving the belt manually before the treadmill stars .
for more details check the link
electronics repair help LIFE FITNESS T3 T3i T5 T5i T7i TREADMILL ERROR...
The amount of fixing motor current reached the specified
value due to torque-up of the pressure belt.
1. Confirm the current value is 80 (0.8 A) and below on
the service mode (COPIER> DISPLAY> FIXING> FXMTR8).
A. In case that the current value is "smaller than 80"
A-1. The pressure belt unit reaches to its life ->
replace the pressure belt unit
A-2. Faulty fixing unit drive gear -> replace the
gear
A-3. Fault fixing motor (M48)
B. In case that the current value is "80 and larger"
B-1. Faulty fixing unit drive gear -> replace the
gear
B-2. Faulty fixing motor (M48) -> replace the fixing
mtoor
B-3. Fault relay PCB -> replace it
2. Clear the current value log of fixing motor on the
service mode (COPIER> FUNCTION> CLEAR> FX-LCLR)
after procedure.
