Question about Dometic Rooftop RV Air Conditioner
We have a Coleman 7300 rooftop ac unit. When the
We have a Coleman 7300 rooftop ac unit. When the ac is switched on the compressor and fan both start working. After a few minutes the fan stops but compressor continues to run about 30-40 sec and shuts off as well. We can manually restart it after 5 min. Same thing happens again. Help!!! Thank you!
  • steve
    steve May 11, 2010
    Check your capacitors.
    Guru:
  • 606 Answers
The fan motor is getting hot and going off on the internal overload in the motor.
This is caused by either a low voltage, a bad capacitor, or tight or dry bearings in the motor.
To check the bearings turn the power off to the unit, then spin the fan blade if it spins freely then the bearings are ok.
To check the capacitor you will need some kind of
tester or you can buy a capacitor and replace it, that's what a lot of people do. They usually don't cost very much.
To check the voltage you will need a voltmeter and measure the volts at the unit.
Posted on Jun 09, 2009
  • Steven ward
    Steven ward Dec 16, 2013
    The only thing that kicks off is the burners the blower motor stays on as well as the inducer motor
6ya staff
SOURCE:
I installed a new rooftop mac 3 48203A876 ac on my travel trailer every things works IE fan high fan low but compr wont start.The unit came with a p.t.c.r. attached to the start CAP. when i set the...
If this is a 'new' unit I would contact Coleman and explain the problem you are having. I would think that they would have to honor the warranty on the unit. That is, if a AC company installed the unit. However, from your explanation of the problem it appears that you might of installed the unit yourself in which case - 'they' (Coleman) might decide to 'not' honor it. A gray area for sure. Still, I would try and see if they would help you.
In the case they won't - I would get ahold of a AC Tech and have him/her troubleshoot the unit before I started removing and adding electrical components.
From what you've said - I wouldn't think you have anything seriously wrong - you just need someone to figure out why it's not working as it should.
My best guess - is that it's a simple electrical problem that can be solved with one service call and for a minimum cost.
Worst case - might be a major component (i.e. compressor) that is bad (which is not likely) but in any event with the AC Tech's help - Coleman would probably honor the warranty on the compressor and you would only be out the labor for the AC Tech to install it. Note: some warranties will even cover the labor to put it in.
Bottom line - I would try to get Coleman to help me directly or with the help of a AC Tech, and in the event they won't - I would trust the AC tech to find the problem and repair it.
Aug 09, 2011 | Coleman Mach III Air Conditioner
Air conditioner blows the breaker when starting up
COLEMAN R.V. AIR CONDITIONER SERVICE AND REPAIR QUESTIONS
COLEMAN R.V. PRODUCTS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
Jul 27, 2010 | Coleman Mach III Air Conditioner
Coleman rooftop a/c hums in all modes, does not start
Replace the start capacitor for the fan and compressor. Check all the wires to the capacitor.
Aug 29, 2009 | Dometic Rooftop RV Air Conditioner
Coleman 7300 rooftop air conditionor wont operate
When they sit allot - sometimes the fan will stick.. Take the cover off,, turn it on and see if the fan is stuck.. Spin it by hand to free it up..
Jul 09, 2009 | Dometic Rooftop RV Air Conditioner
Compressor will not come on. Fan runs great.
I fixed it. I had a dirty connection on the starter relay for the compressor. Thanks again for the help.
May 17, 2009 | Dometic Rooftop RV Air Conditioner
Coleman ac problem
could be bad start capacitor for compressor, cheap fix, anything else could be internal in system or compressor
Apr 10, 2009 | Heating & Cooling
Coleman (RVP) 7000 AC unit compressor problem
I had a problem with my coleman mach 3 AC, we were at an RV park up at lake shasta CA and the fan would stay on but the compressor would come on for a few seconds and then trip off. It was the motor overload relay on the compressor that was tripping. the RV park was old and apparently the wiring to the panelboard at the RV park was too small, when you are drawing a lot of current there was too much voltage drop across their line, to make up for this the motor tries to draw more current and heats up the motor overload and it trips off. I solved this problem by buying an autoformer from Camping World, it senses a voltage drop and automatically boosts the voltage.
I am now having a seperate problem, the compressor is either locked up or has too much back pressure and trips off the service breaker when trying to start. The only solution I can see with my current problem is to replace the entire unit.
Oct 07, 2008 | Coleman Mach 15 Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
1,460 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
Thomas F. Schneider
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
