I unplugged my tread mill for about 30 days. Plugged it in, the screen lights up for a a couple seconds and goes blank again. Turned power switch on and off and same result as above
SOURCE: Tread Mill Skips Jerks Every So Often
Your treadmill is trying to tell you its due for a tune-up!
SOURCE: Tread mill wont turn on.
Dear Sir:
Thank you by your problem, I will help you inmediately.
Make sure that the power cord is plugged into a surge suppressor, and that the surge suppressor
is plugged into a properly grounded outlet . Use only a single-outlet surge suppressor
that is UL 1449 listed as a transient voltage surge suppressor (TVSS). The surge suppressor
must have a UL suppressed voltage rating of 400 volts or less and a minimum surge dissipation
of 450 joules. The surge suppressor must be electrically rated for 120 volts AC and 15 amps.
Important: The treadmill is not compatible with GFCI-equipped outlets.
2)After the power cord has been plugged in, make sure that the key is fully inserted into the console.
3)Check the circuit breaker located on the treadmill
near the power cord. If the switch protrudes as
shown, the circuit breaker has tripped. To reset the
circuit breaker, wait for five minutes and then press
the switch back in.
4)Check the on/off switch located on the treadmill
near the power cord. The switch must be in the on
position.
I hope you resolve this. Otherwise, try to reach me. Inmediately.
sincerely.
E.Cuadra
SOURCE: I just put my tread mill together Nordic Track A2550 and the belt wont move
1) test your circuit breaker home,reset
2)test the outlet for 115 vac
3)test the power cord if some wires is loose or cutting
4)reset your circuit breaker insider from your equipment
5)Eliminate any extension cord from your treadmill.
6)Be shure if the receptacle have ground cable with your divided TRSS.
sincerely.
ERNESTO CUADRA
MANAGUA,NICARAGUA. C.A.
