Red Defy Helmet Youth 2012 Logo
Sophie Strauss Posted on Feb 08, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Two plates do not work
Must i replace ful dtove glass top
Steve Cox
Level 3:
Master:
  • Master 674 Answers
  • Posted on Dec 28, 2018
Steve Cox
Master
Level 3:
Master:
Answers
674
Questions
0
Helped
213284
Points
1718
Yes. The old one is not working due to a shorted area and that effects the entire top.
1helpful
I have a glass topped Soehnle kitchen scale. It was exposed to dampness and the glass plate has come loose. How is the glass plate affixed and is it repairable?
It will depend on where exactly it has 'come loose' from. Considering the cost involved is it worth repairing?
If it is just the glass sheet and none of the working / moving parts, it is held in place with a strong adhesive/glue. It should re-stick with Careful use of a good quality contact adhesive or superglue.
If some of the mechanism has come loose it would be easier to simply replace the entire set of scales.
2answers
What size is the glass tray/plate?
My glass plate broke a very long time ago. you don't really need it. take a regular ceramic plate and turn it UPSIDE DOWN Then you can set anything on top of it to cook. Just a thought and Good Luck.
If you have other microwave problems check the videos below.
One of my glass top plates doesn't work, it goes red and then turns off. How can I fix it?
I have no idea what you're talking about. Glass top plates? In a microwave oven? All I know is the glass turntable tray. And if it's not turning around, you either have that feature turned off (a dedicated button on the control panel), or else the turntable motor is bad.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Looking to replace a broken glass covertop for a Magnetic Induction hob
I looked up your cooktop and discovered it to be made by Frigidaire.
Hence & therefore, try the website "searspartsdirect" and see of they will give you schematics to buy the parts for your needs.
God bless your efforts.
How do i get the middle plate off my motorola i1, to replace the glass?
Hi
you not need to take off the middle plate to replace the glass.
just disconnect the flex avle for the glass and then heat up glass by hair dryer for 10 minute.with tool gently start pulling glass from the top part.
you will be able to remove it completly.
thank you.
2answers
Like many other people I have a vertical line down the copy, using the document feeder, not the plate glass. on my HP officejet J5780 3 in one. Your advice is to clean the small glass plate. I look...
I dont have a picture at the moment but if you lift the document feeder up to expose the large plate glass, the small plate glass is normally situated at the extreme left hand side of the large plate glass.
2answers
I cannot get into the car, the both handles are broken off
it's called the "hammer method"... i think you get what i'm talking about, and nonstructural glass (aka anything but the windshield) isn't expensive to replace anyways. Good luck!
and remember, wear safety glasses and toss the hammer instead of striking it directly. use a small sledge hammer preferably.
4helpful
LHow to clean under side of glass plater
note where the dirt is located,unplug all wires from back, remove top hinged cover, undo 2 screws at the top, remove cover plate by gently tipping toward top, slide glass with plastic sides up and out, clean with approved cleaner, reverse to reinstall glass (plug in power cord prior to replacing top cover plate to check for any missed fingerprints or dirt on underside of glass), once your happy with cleaning complete the reassembally.
I have the SCX-4521. When I feed paper into the top to make copies, the copies come out with a black line in the middle of the page from top to bottom. However, if I make copies by laying the page on the...
Have look where the paper feeds into the tray at the top.
Most likely there is a piece of rubbish stuck in there, another piece of paper or some fluff or something. Blow it out and give it another try.
If this doesnt work open the lid and have a look to the far left of the plate glass. you will notice a small plate glass seperate from the main plate running parallel with the main plate. Clean this with a damp cloth and some window cleaning detergent. Sometimes correction fluid gets wiped off onto this portion which acts as the Scanning Region for documents inserted on the top feeder. This causes a "permanent" black object being scanned for copying, hence the black stripe.
Regards,
BD
Top Red Motorsports Experts
ADMIN Andrew
ADMIN Andrew
Drerangula Siva...
Drerangula Siva...
Level 1 Expert
Are you a Red Motorsport Expert? Answer questions, earn points and help others
