Go back into the machine and check for a disconnected wire cause by cleaning out the filter. Oh and did you remember to turn the water faucet back to the on position? It helps to plug the machine in to the A/C outlet, too. Keep an eye attuned to a safety switch on the access panel as well. It may have an alignment or broken plastic fastening/ mounting design.
SOURCE: zanussi turbo dry 1200
Try cleaning out the pump, and main hose to sump. If problem persists replace pump.
Slim Jim
SOURCE: Zanussi FC1200W
have you checked the filter behind the flap on the front of the machine, this could be blocked. if the machine is full of water though you will have to manually drain it by putting the grey outlet hose into a bucket or a washing up bowl. you will also need one or two towels to place on the floor because there wil still be a bit of water left in the ipes even though the drum is empty.
hope this helps
SOURCE: my zanussi essential washing machine
Sounds like the inlet valve is faulty, though this should not effect the wash. Does it spin?
SOURCE: have a Zanussi electrolux essential 1200 washing
Sounds like the Tachometer on the motor is faulty, this is the built in revolution counter that controls the speed of the motor, unfortunately it means the motor needs replaced and they can be expensive, about half the price of the machine. But if you want to change it then it is quite simple, just 2 or 4 screws hold it in place and the plug an belt just pull off. Hope this helps.
