SOURCE: how to install a panasoinc cq-df903u in 91 integra
The wires for the two harnesses should be color coordinated or at least closely colored. The harness should have come with either a guide that says what is what or the wires themselves have little flags saying what they are. You can use this to match it up with CD Players wires by using the manual from the CD player to know which wire is what.
SOURCE: Panasonic CQ-DF903U How do I hook up my Sirius Radio to it?
Sirius radio connects via a special dock. Sorry, but you're screwed with your XM unit...
SOURCE: panasonic cq-DFX444LEN
The heat is normal due to the large output IC's Panasonic uses. You need to get a "Laser Lens Cleaner" one that uses fluid. You can find them at just about any retail store these days for 15-20. Run it thru a couple times and hope that's the magic bullet to fix the issue, otherwise it needs service at a cost of 100-150 on average. If the cleaner does the trick, make it a habbit of cleaning your player every 3mos or 3000 mi. It truly is the best preventative maintanance on any CD/DVD/PC etc.! Hope this helps
SOURCE: set time car radio/cd Panasonic CQ-C13367
First of all, go to service.us.panasonic.com/operman to get the manual for your unit.
With the unit turned on and the clock displayed, pres disp for more than two seconds. The hours will blink... press < or > to adjust hour. Press disp again, the minutes will blink... press < or > to adjust minutes. Lastly, press disp to store the correct time. Good Luck!!!
