Try this site
Self Help Product Support Konica Minolta Business Solutions Inc
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Konica Minolta bizhub C250
i think that your fax is not set up right, or maybe the machine is missing admin and machine e-mail address, that can cause too this problem.
SOURCE: Bizhub C250
In the Utility Menu you can set the default settings for most functions. Set the copier to the state you wish it to be in. Under the utility menu there is a default setting button. This will allow you to set the current state to the default as well as reset to factory default.
SOURCE: bizhub c250 error code
There are 4 things to try to reset any error codes on these machines
1.) open and close front door
if that fails go to number 2
2.) open front door and turn off main power switch and then turn back on and close front door.
if that fails go to number 3
3.) turn machine off and then turn back on while holding down the utility/counter button after a while a trouble reset box will appear on the screen press on the box and then restart the machine.
If this fails go to number 4
4.) failing all this call your local service agent.
SOURCE: Won't print over network
if same thing happened with c450, then i guess, that the problem is in the network. does the printer answere a ping, also you can ping from printer to network. maybe youll find something. but last option is that you have to upgrade firmware or change network board, also check network settings from printer.
