The code is for the print head which houses the LASER and poloygon motor which allows the LASER to write the image across the drum. Order a new one. Have technician check the electrical connections to the mother board
Yes there are 2 soft switches...... left side is for trouble reset.
Remove fuser unit from copier
Reset code co05XX
The copier needs to give you a scree with wait for warm up; if not some thing else it's going on
If you get the wait for warm up ...eventually you'll get a C05XX code
Reset and test it with the fuser unit in.
Troubleshoot fuser unit in case you get another C05XX
Tom
Sir/Mam either the code is wrong or the model is wrong. The code is for a Minolta or some konicaminolta machines the model you list do you mean Di5510 which is a Konica machine that use Konica codes like SC35-03. Also the machine problem is listed under Bizhub 250 which I could not fine the code for either.
Sir is this a Di450 or Di 550 Model? Then open up the front door and close it.if the code goes away then you are OK if it comes back your LASER print Heard or Printed Circuit Board PWB-B needs replacing. Have a Konicaminolta tech review the TB 3106, 3426, and or 3182.
TCR output abnormality.Toner control ratio abnormality error code.Restart the machine if code removes then its OK otherwise simply replace the developer and execute TCR adjustment again.
